How about with a 1/8" shank?
1 16" 0625" Carbide 2 Flute Endmills Soft Plastic Kyocera Tycom | eBay
Hi everyone,
I've built myself a 5x10 cnc machine and I've been cutting some small detail projects in some formica. It's a very thin aluminum face with a cork backing like a laminate, typically used for cabinets. Anyways, the cuts are very small so I use a 1/16" end mill for the work. I managed to find a couple for sale from sherlinedirect who sell 1/6" bits with a 1/4" shank, but they're all upcut bits. I'm looking for anywhere I can find a downcut bit. Using the upcut bit, I'm getting a lot of pull on the material. I can't seem to get a clean edge on the cuts using the upcut, even when putting the good side facing down.
Any help is greatly appreciated. Thanks.
UCCNC 2017 Screenset
Unfortunately my router only takes 1/2" and 1/4" shanks. Unless I can get a 1/8" collet which fits a generic router.
Check Lowe's hardware online. I think they had 1/16 but don't hold me to it.
Ben
Not ideal, but you can get a 1/4" to 1/8" adapter (bushing).
Thanks for the suggestion. I went ahead and ordered that bit with a bushing adapter. I hope it works out.
Check out drillman1 on ebay. I'm a satisfied customer.
drillman1 on eBay
Thanks for the link. Those are some great prices, I'll probably buy my end mills and bits from them going forward.
I have a porter cable 690 and one of the reasons for selecting this router was that I could get an 1/8" collet from precise bits. They also sell collets for a number of other routers.
Collets, Nuts and Toolholders
They are kind of pricey, but are worth it in my opinion. With an 1/8" collet you can use a variety of smaller bits.
Well I don't do a ton of precise routing. I mainly use my CNC do large cuts in 3/4" plywood so my main bit is a 1/4" up cut spiral bit. I don't see myself really doing a lot of this small scale machining so I hope the adapter will do the trick. I just replaced the router a few weeks ago when my mastercraft crapped out on me and then I broke my Bosch when I changed the brushes. I've got a hitatchi in there now which seems to be doing the job.
Thanks for all the help everyone. I was able to get the job done with the 1/16" downcut bit with the 1/8" shank by using an adapter to fit my router. Cuts were clean and smooth.
