Need Help! Router Speed Controler
Page 1 of 4 1234 LastLast
Results 1 to 12 of 38
Thread: Router Speed Controler
    Feb 2011
    Exclamation Router Speed Controler
    Hello Guys
    Have been a while since I visit this forum. I have a Bosch router on my CNC it is pretty loud. So I did some research and found out that SuperPID will actually lower the noise but it is over $150 . I dig little bit more and found the router speed controller from Harbor Freight Router Speed Control Does anyone using it? I'm thinking to also purchase a hand held tachometer to check RPMs. I know it's not as good as SuperPID but I have 7 weeks old baby that I have to feed and change diapers .
    Dec 2003
    The H.F. is basically a hopped up dimmer circuit.
    So no real comparison, apart from no display, you do not get RPM maintenance control.
    Feb 2012
    I also have a bosch colt. I have a router speed control from mlcs or rockler. Anyway, it does what it is suppose to with the rigid that is in my router table. Bit does not work well with the bosch. It slows it down but it then has a heavy pulsing sensation. Kinda like a chugging effect. It was around $35 range. I think rockler has one that's like $80, but that's half way to a pid. Run it wide open for now and save a few pennies is my plan.
    Feb 2011
    So basically you guys do not recommend it?
    Nov 2010
    I've been using the Super PID for a few months now. It is well worth the money. I works so good. Skip a Latte, brown bag it, this speed controller will make your router into a better machine. Just my $.02.
    Dec 2003
    Quote Originally Posted by Pysiek View Post
    The reviews looked OK, with a few 5 stars!
    Feb 2012
    this is the one I have. $30 on mlcs woodworking. They also have a heavy duty one that $40.
  8. #8
    Feb 2011
    Quote Originally Posted by tatinc2000 View Post
    How is it working for you? Do you using it on CNC router?
  9. #9
    Feb 2012
    This is the one that didn't work well.
  10. #10
    Dec 2011
    If you want good cutting power at lower rpm's get the super pid
  11. #11
    Feb 2011
    Okay. I decided to go with SuperPID.
  12. #12
    Gold Member
    Jan 2007
    super pid 150
    a spindle, 1.5 kw is 250-300...
    if you can listen the loud on a few job, then buy a spindle.. will worth to spend on, because not only quieter, but also can be set more precisely the rpms..
    1 5KW Water Cooled Spindle Motor 1 5KW Inverter Drive VFD Grinding Engraving E7 | eBay
    this one is 230.. compared with a handheld router and super pid...
    probably they have the 0.8 kw spindle too.. works with same inverter..
