Most likely it's an alignment issue. Alignment is extremely critical.The current most frustrating issue is that when if I have the bolts holding the ball screw nuts to the blocks loose 200 ipm is no problem on both the x and the y axis. Everything sounds smooth. If I even just finger tighten those bolts everything goes to hell. Ballscrews get harder to turn, they sounds bad going one direction (not too bad the other direction), and steppers start stalling at anything over about 20-50 ipm. Any ideas why? I thought it was an alignment thing, but with a dial gauge on the block while I tighten those bolts nothing moves more than a couple thou. Anybody else have any issues like this before???
Not likely to be resonance. What screws and motors are you using, and what voltage?I seem to be able to do 200ipm rapids without any problems, which I am fine with. I would like to go higher not for practical purposes but just for show. If I go any higher than that I seem to start stalling the steppers. Would you say that the steppers are just torquing out or is it possibly resonance issues?
