Hey , thanks ... I have this hobby since 2008 ... built about 30 machines since then . The shop is my sanctuary ...I am an air trafic controller ,
and this place is where I relieve stress ... I built all the machines myself ( exept the lathe ... but I'm thinking to build a cnc lathe soon )
Here are some pics ...
on topic ...
The table top is a solid piece of aluminum extrusion ( 450mm x 860mm ) , with 12mm T-slots . The rigidity and strenght of the machines is greatly
improved by using this piece . I had to modify the frame a little , so as the table top will not " eat " from the clearance under the gantry ( is burried into the structure ... ) .
