Build Thread cnc router , aluminum frame , pics only ... - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
Thread: cnc router , aluminum frame , pics only ...
  1. #41
    Registered sgspenceley's Avatar
    Jan 2015
    Default Re: cnc router , aluminum frame , pics only ...
    This is an awesome build thread. I love your workshop, attention to detail and great designs.
    Thank you for sharing...
  2. #42
    Apr 2006
    na
    Quote Originally Posted by katran View Post
    Hey , thanks ... I have this hobby since 2008 ... built about 30 machines since then . The shop is my sanctuary ...I am an air trafic controller ,
    and this place is where I relieve stress ... I built all the machines myself ( exept the lathe ... but I'm thinking to build a cnc lathe soon )
    Here are some pics ...
    on topic ...
    The table top is a solid piece of aluminum extrusion ( 450mm x 860mm ) , with 12mm T-slots . The rigidity and strenght of the machines is greatly
    improved by using this piece . I had to modify the frame a little , so as the table top will not " eat " from the clearance under the gantry ( is burried into the structure ... ) .
    katran do you have any build pic of your mill , great cnc build.
  3. #43
    Registered jpw256's Avatar
    Jun 2016
    Gabriel,
    My name is Jonathan and I must say i am extremely impressed with your CNC mill design. I am building one myself, slowly and modeling it after your design if you do not mind. I am using the HSR25CA linear rail, which is slightly different than your design I believe. I do have a question for you since I am new at these projects. The work base of this machine, how do you fasten it to the rail and beams and what is it? It appears to be some 80/20 or equivalent, however, i have not seen it that wide. Or, is it multiple pieces bolted together?
    I am also using a 2.2KW Air cooled spindle with ER25 collet system. Is this similar to what you have designed?
    I am a Mechanical Engineer and Gunsmith by trade. I saw that you were an Air Traffic Controller. That must be a stressful position. Especially in the times we are in today.
    I greatly appreciate any input you may have and I thank you for your time.
    Have a wonderful weekend.
    Jonathan
  4. #44
    Jan 2017
    Denmark
    Hallo do you make this mashine for sell, and if what is the price on that.???????
    Kim m.
  5. #45
    Dec 2015
    Hi Gabriel. How do I get a hold of you? Your email must be down and you don't seem to be getting PM's...
  6. #46
    Jun 2005
    You do beautiful work man, you are extremely talented to learn all this stuff CAM/CAD, machining, construction, electrical, and you are still an air traffic controller. You are like superman.... Congratulations.
  7. #47
    Mar 2008
    Hello Katran,
    Can you PM me I have some questions.
    Very nice work!
  8. #48
    Jun 2017
    Hello Katran,
    I am very impressed with your work and would like to know if you are willing to sell the CAD files and parts list.
    thank you.
  9. #49
    Dec 2015
    @rioan28
    Katran is sort of a douchebag, so he won't respond to your message. You can, however, find some CAD files of his machines here: https://grabcad.com/gabriel-57/projects
  10. #50
    Jun 2017
    Thank you.
  11. #51
    *Registered User* Ironman1952's Avatar
    Nov 2018
    Default Re: cnc router design
    I am in the US, and I wanted to say I like your machine design. I do custom furniture pieces and want to build a machine 3'X6'
    To do mainly carving type operations. I want to build something similar to your using a steel frame with aluminum gantry. Double ballscrew in Y single in X and Z.
    Can you tell me what suppliers you Used?
    Did you do your own machining?
    Can you suggest any reading or articles?
    Thanks, Joe. :-)
