Some photos and history of a CNC router I built. Much of the design was influenced through posts I've read on this Forum, so I thought I'd give something back to the CNC Zone community and hopefully inspire some further builds.
I built this router for the purpose of machining composite material moulds for a concept car I was involved with building. Primarily the machine has been used to machine foam, wood and resins.
Sadly I need to relocate workshops and there is insufficient room to relocate the machine to the new premises. Subsequently it's now for sale and is listed on ebay: http://www.ebay.com.au/itm/251248895...84.m1555.l2649
Construction:
- RHS steel welded construction X-axis supports and Z-axis.
- I-beam steel Y-axis gantry, machined flat and true to X-axis.
Cutting area:
- X: 1450 mm
- Y: 2250 mm
- Z: 650 mm
Mechanical movement:
- Linear rails on all 3x axis
- Ball screws on all 3x axis
Servo motors:
- DMM-Tech AC Servo with encoders (4x 92M-DHT-72 / DYN2-H)
- DMM-Tech break-out board
Controller:
- Mach 3
- Dell PC with HP 14" touch screen monitor
Spindle:
- Chinese 2.2kW ER20 collet water cooled spindle.
- SAJ VFD
