Jim,
How about a simple relay that is turned on by a TIP 120 transistor? I am assumming that you are controlling it from your parallel port.
Relay example.
Chris
Hi Gang I'm looking for a circuit to turn my router on and off in s\w
anyone have a schematic that I can build.
I'll likely be using turbocnc. Thanks........Jim
Jim,
Relay example.
Chris
On a side note you need to be careful with them. Watch for false starts. Be sure the power is turned off when you start your computer and your controller program.
Chris
Thanks a lot Chris I'll have to do that because a file I want to run will take about 17 hours to complete.......Jim
here is a drawing. the top picture is the one you need.
Eric
I wish it wouldn't crash.
Thanks Eric that looks like what I need, I have some mechanical relays laying around.............Jim
