Hello my huyonyang vfd has been refusing to turn off or slow down, resetting the control to the box itself would not help, neither doing a factory reset.
Is there anything I might do to fix it? if not Is this New Hitachi Inverter X200-022NFU2 Input 200-240v, 1 or 3 phase, 3 HP 10 amps | eBay a good replacement?
Also is the parameters / wiring much more difficult than the old vfd? most of the reason I bought it is because of the amount of documentation.
