How to burn flat images in wood?
Results 1 to 2 of 2
Thread: How to burn flat images in wood?
    Aug 2003
    Default How to burn flat images in wood?
    Has anyone ever added a wood burning type tool to a cnc router? I mean like a torch or something. I know the best way to burn a flat image into wood would be to use a CO2 laser, but that is very expensive. There must be an alternative to expensive lasers.
    I see allot of software for making images in wood like ImageCarve, DeskArt, or ArtCam. But those are pretty much 3D relief. I was thinking more of just a flat burned image like a CO2 laser can do.
    Any ideas?
    Registered ToyMaker's Avatar
    May 2003
    Anyone remember the "Ungar Woodburning Set" (from the '50s-'60s, IIRC). It was a low-wattage soldering pencil with various shaped tips.
    Mount a soldering iron on the z-axis. Speed and feed could be found with trial-and-success.
    robotic regards,
    Tom
    One father is better at caring for ten children than ten children are for one father.
    - - Proverb
