Build Thread MDF Madness - Page 29
Page 29 of 32 FirstFirst ... 1926272829303132 LastLast
Results 337 to 348 of 377
Thread: MDF Madness
  1. #337
    Registered cd_edwards's Avatar
    Sep 2011
    canada
    My router is always on. I never use the switch. I have it controlled by Mach3 and a relay. It's also controlled by the superpid2 run signal. Mach3 on a M3 command sends a run signal to the superpid2 and also turns on a relay which is supplying power to from the superpid to the router.
    Colten Edwards http://www.cncsigns.ca
  2. #338
    Registered cdrd03's Avatar
    Mar 2006
    I had though of using a relay, but hasn't gotten as far as looking for a5v relay. What relay are you using colten?
    Chuck
  3. #339
    Sep 2011
    canada
    Just a 12v relay. You really need to have a safety interlock though if just using a relay. This is what the superpid provides. without the run signal, the superpid cannot power up the router because the router relay is off.
  4. #340
    Nov 2007
    I run a similar setup but without the SuperpID. Router and shop vac are always on. I use a ssr25. Very convenient having the dust collection and router turning on/off with gcode.
    Quote Originally Posted by cd_edwards View Post
  5. #341
    Registered r00t4rd3d's Avatar
    Mar 2012
    Thankfully Dewalt came through and got me the motor brushes today.
    My old brushes:
    MDF Madness-dsc03017-jpg
    What new brushes look like:
    MDF Madness-mvudqjog1lmyk6excwmufxg-jpg
    And finally got started on a sign I promised to have done by the 28th:
    MDF Madness-dsc03011-jpg
    My CNC Router Build - http://tinyurl.com/c3vs3ca
  6. #342
    Mar 2012
    Breaking Bad!
    MDF Madness-bb-jpg
    Attached Files Attached Files
  7. #343
    Mar 2012
    I seen this thing on Reddit, a CNC Machine that rests on top of a stack of plywood.
    Impulsive Furnishing Unit ? Frame Moooi Award winner « Christian Fiebig
  8. #344
    Gold Member
    Apr 2007
    Looks interesting. It may be a bit flexy in mid span though.
    CarveOne
    http://www.carveonecncwoodcraft.com
  9. #345
    Mar 2012
    I spend more time thinking of what to do with my scrap wood then anything.
    Cell Phone Recliner
    MDF Madness-img_20130920_193051-jpg
  10. #346
    Mar 2012
    Headphone stand.
    MDF Madness-img_20131102_120637-jpg
    MDF Madness-img_20131102_120717-jpg
  11. #347
    Registered Arbo's Avatar
    Jan 2008
    Nice, I was thinking about something like that just yesterday.
    Wood neophyte.
  12. #348
    Jan 2008
    canada
    Me too! And this is much classier than he styrofoam manniquin head that I was going to start with. Thanks!
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
MDF Madness
MDF Madness
