Router Bits and EndMills: Pictures, Descriptions, and Uses - Page 3
Page 3 of 15 FirstFirst 12345613 ... LastLast
Results 41 to 60 of 290
Thread: Router Bits and EndMills: Pictures, Descriptions, and Uses
  1. #41
    Apr 2009
    Quote Originally Posted by racedirector View Post
    Thanks Gerry
    By "set" I just meant a collection of bits to buy. My list is pretty much what I *think* i would need - 3mm for cutting out things like the puzzles and small holes, 6mm for profiling etc, Vee bits for carving the ubiquitous Myan calendars etc and ball ends for smoothing.
    I'll check out ebay for small bits, I seem to remember someone recommending drillman (or similar) for them. Initially I will have to buy locally (A$$$$$$$$$) but at least they will be me started while I wait for the ebay purchases.
    Cheers
    Bruce
    drillman is a good example of someone on eBay who sells high quality bits for a good price. I've purchased from him, and shipping was very fast.
    If you buy bits locally, try Freud Diablo (red), Bosch (blue), CMT (orange), or Porter Cable (darker red). I've had good luck with Sears Craftsman bits. Stay away from any Ryobi bits (blue). I've had nothing but bad luck with them. You can even find Whiteside (no paint) at some woodworking stores.
    One reason of starting this thread was to make others aware of these quality brands, and that you can get them for a lot less than you think, and maybe only a slight premium over the cheap Chinese stuff. Solid carbide bit bblanks are sintered, meaning the blanks are made from powdered material compressed with high heat to form the blank. With the more reputable companies, the quality control on these blanks are quite high. Who knows with these cheap imports? I've had more break than I could count.
  2. #42
    Member LouF's Avatar
    Sep 2011
    I would like to say Thank you Louie for starting this thread and Thank you Gerry for your input on various bits I just purchased some from E bay Onsrudcutter2010 and saved some big $$.
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  3. #43
    Nov 2011
    Quote Originally Posted by louieatienza View Post
    Thanks Louie for both your replies, they have extended my knowledge greatly. I'll just buy a few bits at first and then get what I need when I need them.
    Being in Australia I am dependant upon ebay and US suppliers that will ship internationally. For my initial local purchases I will be buying HSS bits from McJing in Sydney (McJING Online Tools Products Search) as carbide bits are way to expensive here. For US based suppliers I found these guys: Cutting Tools Source End Mills Cutting Tools Custom End Mills CNC Machine Tools Burrs & Drills who make all their own bits out of solid carbide. I might grab a few from there too unless someone advises against it. As for other US suppliers, I'll just use Google to find them again unless people have recommended suppliers they use frequently. I'll also order from drillman for the smaller bits as I need them.
    Cheers
    Bruce
  4. #44
    Aug 2011
    UK
    I've seen a few people say they pocket out any internal cutouts, to avoid moving material and broken bits.
    I wonder what the difference is from wanting to keep the small cut outs, if you were making lots of small parts, for instance ?
    Are Tabs the way to go, or the 'onion skin' method of not cutting all the way through , or both ?
    Surely pocketing is just making more dust, and creating more wear on the cutters ?
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
  5. #45
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I've never used tabs. I prefer the onion skin approach myself.
    I also never pocket out cutouts, but I can see Louie's point if the cutouts are phenolic.
    But, I don't use bit's any smaller than 1/4" when cutting out parts, so breakage from loose wood cutouts isn't really an issue.
    Small parts can be very tricky, and different parts can require different methods
    UCCNC 2017 Screenset
  6. #46
    Aug 2011
    UK
    so should I not be too worried about my 1/4" spirals ?
    They've shot a few bits off the table , but been ok so far.
    Rich
  7. #47
    Nov 2007
    Quote Originally Posted by TrickyCNC View Post
    Rich
    I suppose that depends how ridgid your machine is. If the cutout gets jammed then some deflection could happen.
    I use tabs most of the time but I get a cleaner cut when I use the onion skin method. My z axis alignment must be a bit off.
  8. #48
    Sep 2011
    I have used tabs on Acrylic when the protective film is gone never on a wood project but I am a newbie...
    Lou
  9. #49
    Apr 2009
    Gerry to note, I snapped a 3/8" bit, which was carbide body with PCD tips!
    There are a few thoughts on this. It really depends on what you're doing.
    For harder materials, pocketing may be the way to go. Especially if it's a long run with many holes. You might think that you're wearing the bit more but it may not be necessarily true. If you pocket and use a large enough bit, you can take deeper cuts, even through cuts, and take more aggressive rough cuts. You'll generate less heat since you're cuting more on the edge of the tool which is way more efficient than the bottom. The finish pass would then be the full depth profile. You'll actually get better tolerances this way, and it's the way they do it in metals. Some CAM (even Cut2D) have rest machining for pocket clearance as well. If you profile cut the holes, you'd normally have lower doc since you have full width bit engagement. You're climb cutting on one side and conventional on the other, so the bit wants to move toward the conventional side. If your machine is not super-ridgid, you'll have tolerance issues. I understand m machine is not the stiffest, therefore to achieve a certain tolerance, I run finish pass on 'mission critical' features.
    For larger holes, it may be beneficial to do a drill op on the center of the holes and fix the soon-to-be slugs down with screws, before cutting the profiles out. Another way would be to onion skin with a larger bit, then come back with a smaller bit to profile cut the rest out. The smaller bit won't grab as much, and the onion skin will prevent the slug form binding the bit. Yet another way, and probably only worthwile if you had to do a large run, or have many holes, is either to raise the workpiece, or create a fixture with pockets or holes, this way the slugs fall down and out of the way. Yet another way would be to tack the slugs down with a 23ga pinner.
    I had to cut out some letters out of thin gauge (1/16") brass sheet. The best way I found was to glue the sheet down with CA glue, let it cure, profile cut the letters, then remove them with acetone. I tried spray adhesive but there is always a little 'creep' and the glue gums up the bits. Plus if you spray a tiny bit of lubricant it will work under the letters and pop them out and ruin them. I got the tip from Ron Reed at precisebits.com.
    But yes, when cutting out holes, you'll have to assess the situation and consider the tools you need when deciding whether to pocket or profile.
  10. #50
    Apr 2009
    Quote Originally Posted by jckstrthmghty View Post
    Or worse you stall a stepper and lose position, or the jolt of the slug forces the bit to put a divot on the edge of your profile. You may not even know you lost position until the job is done, and the features on one side are off.
  11. #51
    Apr 2009
    Quote Originally Posted by LouF View Post
    Lou
    Believe it or not, I've kept the bottom film on Mic-6 aluminum plate and have profile cut right to the film, keeping the part in place, though I've only done this on a couple pieces.
    You might want to use tabs on a 3D relief, like an ornamental, where there are intricate details that may get lost or not be as crisp by sanding the onion skin off.
  12. #52
    Sep 2011
    I did that the other day it don't happen to often but it was cool I lifted it right out all that stayed was the film..
    Lou
  13. #53
    Registered Walky's Avatar
    Jul 2009
    Chile
    On the right, I have 10 Kyocera 1/8" spiral-"O"-flute endmills. These are designed mainly for plastics, but I think they should work for aluminum as well. I got these 10 for $29 on eBay; that's about the cost of a single one from Onsrud.
    Are those from drillman1? Have you tried those with aluminum? I've had my eye on those for a few days.
  14. #54
    Apr 2009
    Quote Originally Posted by Walky View Post
    I haven't tried yet. The sweeper on the tip looks a little wider than on an Onsrud, so I'm concerned that it might try to take off too much material. But at $2.90 each, what the heck?!
  15. #55
    Sep 2011
    Louie I am subscribed to your you tube channel I really enjoy the videos what did you use to carve the aluminum Harley Davidson logo? Some great work I was showing my wife and Daughter they really like the videos as well.
    Lou
  16. #56
    Apr 2009
    Lou
    Lou, thanks! I used both a 1/8" spiral-O-flute from Amana, and a 1/16" 2-flute carbide endmill from Enco. Glad the whole family likes the videos, though they may not be the most entertaining!
  17. #57
    Member Boltz's Avatar
    Mar 2010
    Default spoilboard cutter
    I really like this Amana spoilboard cutter. The inserts are 2 bucks a piece and they have 4 edges.
    Attached Thumbnails Attached Thumbnails Router Bits and EndMills: Pictures, Descriptions, and Uses-cutter-003-enhanced-jpg
    Buy my Multicam!
  18. #58
    Sep 2011
    Louie thanks for the information I forgot to ask you what spindle speed and feed rate?
    My wife and Daughter have a embroidery machine and are in to basically the same thing but the use fabric so this is up there alley
    Lou
  19. #59
    Mar 2010
    Default no more vortex?
    Hey Gerry, you used to have a lot of praise for Vortex, what changed?
    Quote Originally Posted by ger21 View Post
    Here's a few that I use.
    First one's what I use for my spoilboard. 2-1/4" diameter. It's just like a slot cutter, without the bearing. I got it used for free, and cut the shank down with a grinder, as it was 4" long. It needs a little cleaning. Vortex sells something similar, but they're not cheap.
    Second one is a 1/4" "O" flute that I use for plastics. Works great for plexiglass, no melting. Sorry about the blurry picture. Got it from CNC Toybox.
    Third one is just what you need to cut through 1" board in one pass at 1200ipm and 15,000rpm. 3 flute coated compression from Onsrud. Just got 7 of them in the mail today.
    When cutting laminated particle board, the laminate is so abrasive that a good size groove will wear into the tool in as little as 20-30 sheets. I've cut 80 sheets with one coated tool without ay wear grooves.
    Fourth one is a 2 flute upcut chipbreaker from Onsrud. Great for hardwoods and hard plywoods, as they cut with much less power required than a standard spiral bit. These are also really good for cutting deep mortises.
    Last pic is about $1200 worth of router bits.
    Buy my Multicam!
  20. #60
    Apr 2009
    Quote Originally Posted by Boltz View Post
    I want one when I have the cash for it!
