Free plans for my Digitizing Probe and Pen Holder - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Free plans for my Digitizing Probe and Pen Holder
  1. #21
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Quote Originally Posted by IBBruin View Post
    I do have a question about the txt file generated by using the digitizing wizard in Mach. When I open the file that's generated during my probe it only has a list of numbers like this:
    1.487484,2.465796,6.346739
    1.567484,2.402796,6.334739
    1.387484,2.775796,6.395654
    1.569484,2.465796,6.391239
    These are not the exact numbers but this is the format stored in the file. I understand it's xyz coordinates but there are no M or G codes or feed rates, just numbers. Am I going to have to edit and put in my own M and G codes or did I miss a step somewhere?
    Download MachCloud from the machSupport site, which will create an .stl file from your point cloud. then you can use a CAM (MeshCAM, Cut3D, etc.) program to create gcode from the .stl file.
    UCCNC 2017 Screenset
  2. #22
    May 2012
    I know this an older thred.. But I can't seem to get the Digitizer probe PDF to download. Is there another place I could find the info at?
    Thx,
    Kev
  3. #23
    Jan 2010
    The 'digitizer master.dxf' above works for me. Anything you see posted that downloads from MegaUpload is forever lost though.
    The pen holder pdf appears missing, but likely the same as this Grunblau post on Instructables - http://www.instructables.com/id/Coil...-CNC-Plotting/
  4. #24
    Member Grunblau's Avatar
    Jun 2008
    Michigan, USA
    Quote Originally Posted by RetArmyEng View Post
    Thx,
    Kev
    Sorry I did not see this earlier... Here is a page I made awhile ago where I sort of archive stuff I have posted here and elsewhere. I have not posted the digitizer on Instructibles. I plan to, but I want to make an all CNC version that is a bit smaller.
    Click Here for Files
    Hope this helps,
    Brian
