Lol, I saw those yesterday as I'm after some encoders! I found some others which I will bid on towards closing time though.
I was cruising ebay yesterday and picked up this little set of servos.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2548619133
I really only bought them for the 200ppr encoders. I figured that $30 for a set of encoders would be a good deal even if I cant use the motors. But I wonder if the motors would actually be usable... I couldn't find the math to figure out how much power I'd get out of them. I wonder if they'd be as powerful or more so than the steppers that I am runnning. I could not find out any specs on the motors other than they are 23v - 13watt motors.
Nathan
There are 746 watts in a horsepower. You do the math. I would say they are a great deal for the encoders tho!
Since they are 3000 rpm, if you went belt drive down to 6:1 I am positive they would be more powerful than steppers. A 5 volt, 1 amp unipolar stepper is 10 watts in. they are not 100% efficient so maybe 7 watts out.
If you are buying servo drives anyways, hook em up and check it out!
Eric
I wish it wouldn't crash.
Yay, I just got some servos too! Sorry for playing this one close to my chest, but I really wanted them! Check them out here. Balsaman, the other servos which I was testing seemed ok, but after i found these, I thought I'd keep the others as spares. After all, a big 24v PSU will be easier to find than a big 80v too.
Well that works out to be...
0.0174263 hp
23 V
0.57 A
40 ohms
13watts
how does gearing down affect torque. (I know it increases but at what ratio?) lets say you had 1lb of torque and you geared that 2:1 does that give you 2lbs of torque or is it a bit more complex than that?
I'm currently using 16tpi threaded rod. until I can bone up for real screws. Gearing down 6:1 would give me a max of only 31.25ipm.
6:1 = 500rpm / 16tpi = 31.25 ipm
3:1 = 1000rpm / 16tpi = 62 ipm
2:1 = 1500rpm / 16tpi = 93.75 ipm
So until I do a leadscrew upgrade. only a 2:1 would give me any real speed increase as I can jog almost 50 ipm with my current stepper setup. I don't know how that .0174hp would translate into actual force.
and yes I've almost convinced myself to go ahead and buy some Geckos in anticipation of going servo. I might just go ahead and pick up one to mess with until I get the motor situation together.
Nathan
Nathan:
The torque multiplication is exactly like you wrote it, at the expense of speed; 2:1 ratio doubles the torque and halves the speed. Less a little for friction of course.
robotic regards,
Tom
Since you are using 16 tpi rod, you can get away with less reduction, because the rod itself is a reduction, like a shallow inclined plane.
Buy a gecko and bolt it on!
Eric
Kong, those servos will need an external encoder. Good price!
Eric
I'm on the case!Originally posted by kong
Ok, at the risk of someone else getting them, I'm currently watching these
F-it I just ordered 3 geckos.... (I needed to put the child tax credit check to use somewhere.... )
Now.... I need everyone to be on the lookout for a killer deal on a set of "real" servos... I've already pushed the "Toys" budget for the next month or two. So killer deals only need apply.... (I know some of you guys are hoarding dozens of these things away greedily and can spare 3. )
I'll give these little Hitachi motors a spin and see what happens. I'm still not terribly optimistic though. But then again it might be suprising. I know that my 14v cordless drill will send any of my axis flying with very little effort. and I'm suing UMHW slides on aluminum channel currently. There will be much less force required when I upgrade to real linear bearings in the next few weeks.
Nathan
Mate, I'd offer my spares, but a) I don't know what kind of torque they are putting out and b) I live about 2000 miles away in UK so the postage would be about $1Million. Just keep holding out for that ebay deal and they will turn up, they have for me.
Kong
I just got hold of 6 of those. They're pretty chunky beasts but should be great for our needs. As for encoders you may want to check out farnell. They've got some solid state hewlett packard encoders for about £30 each which are perfect for the above. 5V and 17mA supply, quadrature units which should be just right for interfacing to Geckos. It's great to see useful lots appearing this side of the water. The guys over in the US don't know how lucky they are getting all the good deals. I've just ordered some THK linear rails and carriages from a chap in the states - the units were a very good price but the shipping was the best part of £200!
The US getting all the good deals, you got that right! I think the servos are the only part of my planned machine to come from the UK, and on my current machine, the steppers and driver board were both american! As for farnell, well I hate paying full price for anything so I'm keeping my eyes on ebay. Don't suppose you know of anywhere to get some cheap linear shafting do you? Cheapest I have found is RS electronics.
I saw that shafting on RS myself. It's SKF unless I'm mistaken. It's actually at a very good price. You can certainly get cheaper elsewhere but it won't be of the same standard. It all depends on what bearings you're planning on using on the shafts and the load they'll be carrying. If you're using plain bearings or oilite bushings then you can probably get away with unhardened shafting or even drill rod but if you're planning on using linear ball bearings then you'll need something hardened otherwise it will wear very quickly. I'm a little biased towards SKF as I worked for them a couple of years ago - I wish I still did - my current machine would have been half the cost nevermind, anyway that shafting is manufactured in a small town called Hofors in the middle of nowhere over in Sweden. They produce some of the best steel in the world over there. SKF's components are rarely the cheapest but most in the industry would agree that they're without doubt of the highest quality. I think RS have also got the SKF compact linear bearings for 16mm shaft at about £10 each which seems pretty reasonable. I don't know if you've had a look at www.ondrives.com, they've got some useful kit as well. What are you planning on using your new machine for? Have you decided on a spindle yet. I've noticed that a lot of guys on this forum have opted for either Porter Cable or Makita routers, both of which seem very capable. Unfortunately over here the only Makita models you can get are designed fo hand use only and as such have that unsightly plastic molding that makes it almost impossible to mount. I'm thinking of buying a Makita RF1101 from the states and making a 110V supply to run it off. Does anyone know of a speed controller for such a router, something that could be driven from turbocnc or mach2 for example. Balsaman I see that you used a speed controller for your latest machine, was that homemade or bought in?
The spindle I have at the moment is a B&Q "pro performace" fixed head router. It is the only American style router I have seen over here. Not a bad unit, 1250w, 1/2" collet, and possibly the poorest quality 15 piece cutter set you're likely to find, but for £52, a bargain.
My speed control came from a vibrating table (like a conveyor that shakes the parts along). I had to fix it. All it does is vary the ac voltage to the shaker unit which is just what you need to vary a routers speed. It works like a charm. It's just a circuit board.
Ones made just for routers can easily be found on ebay for $30.00. They have the plugs and everything.
Eric
Eric,
I came across a box at work a couple of weeks ago stuffed in the maintenence room by itself. It has a big knob on it and it says variable speed something or other. On the knob I think it said Ohmite or something. It had what looked like a standard 3 prong drounded AC outlet on it.
After reading your post, Im wondering about this box. It had no other markings on it.
Ever hear of anything like that ?
edit: I did some searching and Im thinking it is a Variable AC transformer. I will chack it out tomorrow. Is this what you are describing for speed control for your router.
Wee aim to please ... You aim to ... PLEASE.
It's probably some kind of variable resistor. If it's very large, it might work, but it will get hot. That's how they used to do it.
Eric
Eric,
It is a variable speed control (for what I dont know).
It says it is an variable AC transformer.
It is rated 120 V, 5.6 A. The routers I was considering were 10 amp models.
Sorry for hijacking the thread.
Back to these encoders, are these going to work with Geckos? I am asking because I was just about to bid on the ones I mentioned earlier, but then I noticed an extra $15 admin charg for international orders! Also, I notice the ones you have are magnetic encoders and as I have not had time to check them out, I thought I'd check first as there are some more on ebay.
