Super-PID new low-cost router speed controller - Page 195
Page 195 of 195 FirstFirst ... 95 145 185192193194195
Results 2,329 to 2,338 of 2338
Thread: Super-PID new low-cost router speed controller
  1. #2329
    Feb 2012
    Default Re: Super-PID new low-cost router speed controller
    Thanks Ger. I read that part of the manual 10-15 times and it never clicked til now. Sorry for being a pain in ___.
  2. #2330
    May 2014
    I ran a SPID with a Makita router with no problems. I upgraded to a Porter Cable 7518 and am still trying to get it to work. Are there any special things that need attention. The SPID screen just cycles through the menus. The router runs and stops. I have adjusted the optical sensor. Do I leave the TRIAC in and jump it or should it be removed. I have a CNCROUTERPARTS NEMA 34 electronics cabinet with PMDX 126 board. I initially wanted to run the router with the software but just basic running would b a good start.. Any help appreciated.
  3. #2331
    Oct 2014
    Hi guys, i have the Super-Pid, Ethernet Smoothstepper and C10 breakout board, i have 4 wires from S-Pid to BoB, i can turn on/of and fully control the speed, but i can't get the RPM display to work, been messing around with the index input but no luck. Can someone please help me how tn configure mach3. Thanks...
  4. #2332
    Mar 2003
    Are you using the default screens?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  5. #2333
    Oct 2014
    yes, default screen...
  6. #2334
    Mar 2003
    Do you have it wired like the manual shows? How do you have it configured in Mach3?
  7. #2335
    Oct 2014
    like i said, 4 wires (gnd, tach, run, 5v) from s-pid to bob (gnd, 8 to run, 9 to pwm, tach to input 10), i can turn on/off and fully control the speed of the router. In mach3, enable index and assign port and pin, try to stick and unstick active low also. In spindle setup tab, stick use spindle feedback in sync mode. Also tried to put some number in index debounce box. Im not sure if i have to do anything with ess plugin or what.
  8. #2336
    Registered Spotswood's Avatar
    May 2011
    What router is considered to be the easiest to install the RPM sensor?
  9. #2337
    Nov 2010
    Quote Originally Posted by Spotswood View Post
    Well I'm sure everyone has an opinion.
    I found the Porter Cable 690 a good choice for my needs. There was adequate room on the top part of the router. I have a small lathe, so I was able to machine the needed hardware which holds the speed sensor. I silver soldered the two pieces I fabricated together and then drilled and tapped a whole on the router to mount the assembly.
    Also Precise Bits makes collets that fit this router.
    Attached Thumbnails Attached Thumbnails Super-PID new low-cost router speed controller-dscn0437-jpg   Super-PID new low-cost router speed controller-dscn0436-jpg   Super-PID new low-cost router speed controller-dscn0433-jpg   Super-PID new low-cost router speed controller-dscn0430-jpg
  10. #2338
    May 2010
    I found the Porter Cable 8902 was fairly easy to modify. I may have also posted the mod process on this forum but I also posted it here: Build Your Tools ? View topic - Super PID
    airnocker
    Everything depends on everything else
