Thanks Romanlini for your prompt late night response!
I'm glad the Super-PID pull up on "RUN" is weak enough that it can be pulled down with the 470 ohm, that's what I was hoping for. Yes, I was planning to use the relay to switch the +5 supply to "RUN" when active. Thanks much for your support offer! I'm also an Electrical Engineer, so answering these questions is just the kind of support I need.
I hope to have it running before the end of the day!
Todd
