My Router - NEW PICTURE UPDATE !
Results 1 to 14 of 14
Thread: My Router - NEW PICTURE UPDATE !
    Jun 2003
    florida
    Cool My Router - NEW PICTURE UPDATE !
    ++++MORE PICTURES LOWER IN THREAD +++++
    Ok - 3rd Edit... I have the X rails mounted and the gantry - see below. The gantry pic shows that I removed the side pieces of tooling plate to make bolting the rail down easier... Ill put them back on later today after work and put the Y rails on today also.....
    Look for more pictures Tuesday or Wednesday..... I am waiting on my machinist to get a couple parts to me and Ill have everything i need to get it finished and running. I already tested the electrical and drivers / steppers - went well.......
    See todays pic below
    I'll keep posting
    Attached Thumbnails Attached Thumbnails My Router - NEW PICTURE UPDATE !-cncframe-jpg
    Registered balsaman's Avatar
    Mar 2003
    Keep posting it looks like an interesting machine. I would like to see more as it progresses.
    Eric
    I wish it wouldn't crash.
    May 2003
    What plans do you have? are they available online or did you design this table?
    Jun 2003
    florida
    I actually purchased a couple sets of plans - to learn from and as a guide... Then I designed my own machine..... I simply couldnt find a machine plan the size and style I wanted so I did my own ( after a LOT of research)
    Tom
    Jun 2003
    florida
    Below are the Machined Aluminium Plate that support the X rails -- This is just before final fastening which I am doing later today. Tomorrow Ill be mounting the linear rails ( X rails) - Round 3/4" on Alumium bases to the plate. You can see all the drilled and tapped holes that will hold the rail assemblies down.
    Attached Thumbnails Attached Thumbnails My Router - NEW PICTURE UPDATE !-xaluminium-jpg
    Jun 2003
    florida
    One last pic (for now)
    Attached Thumbnails Attached Thumbnails My Router - NEW PICTURE UPDATE !-xrails6-jpg
  7. #7
    Registered HomeCNC's Avatar
    Mar 2003
    Nice looking! Did you have any trouble getting the top of the welded frame flat for the aluminum to sit on? Oh I remember the fun of getting the ways running parallel and level
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
  8. #8
    Jun 2003
    florida
    Jeff
    Thanks for the nice comment - been working really hard on this.......
    What I did was located the highest point on the frame (as you know the steel is NOT straight) Then spot welded small steel tabs in the 4 corners the same height..... Then cross checked it, and added more tabs.... checked it again.... bingo.... I used a 72" precision straight edge and a master machinists level... I figure I got it right to within .004 Not bad.... Ill make any adjustments I need to while bolting down the linear rails.... got plenty of shim stock..... But I think it will be fine.
  9. #9
    Jun 2003
    florida
    Default PICTURE 7/29/03
    Here is todays photo
    Attached Thumbnails Attached Thumbnails My Router - NEW PICTURE UPDATE !-cnc5-jpg
  10. #10
    Registered CAMmando's Avatar
    May 2003
    Phila PA, USA
    Wow ... thats quite a machine !
    What kind of motors and drivers are you going to be using ?
    Wee aim to please ... You aim to ... PLEASE.
  11. #11
    Jun 2003
    florida
    CAM -
    Thanks for the nice comment - I have worked long and hard on designing and building it. I must have done something right - if you push the gantry with one finger - it will travel the length of the table - and it weighs (without motors, Y rails, and y to Z plates) about 120 pounds.
    I am using Sanyo-Denki Stepper motors, 8 lead, wired in series on a 48 volt power supply, with Gecko 201 drives.
    Control is with Ability Systems LPT Indexer , and their G-Code controller... Like I said - I already did a preliminary wire up - all went well..... Ill post a pic of the electrical cabinet tomorrow along with a few more pics......
  12. #12
    Jun 2003
    florida
    Default More Pics
    I got the Y rails on.... adding the Y to Z plates this weekend..... I am waiting on new screw nuts - I was sent the wrong ones....
    But will have everything else complete by Monday and running on Tuesday !!!
    Attached Thumbnails Attached Thumbnails My Router - NEW PICTURE UPDATE !-tcnc3-jpg
  13. #13
    Jun 2003
    florida
    More pics
    Attached Thumbnails Attached Thumbnails My Router - NEW PICTURE UPDATE !-tcnc1-jpg
  14. #14
    Jun 2003
    florida
    SEE MY NEW POST " UP AND RUNNING FOR MORE PICS !!!!!
