Need Help! How can I test my CNC controller or can I find training for EMC??
Results 1 to 4 of 4
Thread: How can I test my CNC controller or can I find training for EMC??
    Aug 2010
    Kuwait
    Default How can I test my CNC controller or can I find training for EMC??
    Hi everyone..
    finally, I got CNC controller from http://www.hobbycnc.com/. and I downloaded EMC software from http://linuxcnc.org/. but I did not find any training for this software!! .. can anyone help me .. I want test my kit. after that, build my CNC machine.
    I'm using Ubuntu 10.04 and I install that EMC software by VMware.
    thanks for all.
    Apr 2003
    Quote Originally Posted by q8istud View Post
    Hi everyone..
    thanks for all.
    That won't work.
    You have to use a real time modified kernal for EMC. The highest easily supported is Hardy Heron.
    You can load a live CD and run (Very slowly) off it.
    DO you have any windows machine or a dos machine. Turbo CNC is totally free to use, easy to set up and runs under dos. It must be real dos not a dos prompt from windows, You can boot to real dos in WIn 95 and 98.
    So if you want to test under Linux download a Live CD for EMC and boot to the CD. With CNC you are running hardware and virtual machines don't hack it.
    A good place to start with EMC is here..
    which I see you have been to but if you are trying to run as a virtual machine you must not have done much reading while there..a cut and paste follows and on the page there are hyperlinks..
    "Here you'll find information about the software, how to get it, how to configure it, how to run it, and especially where to ask for help.
    Community maintained wiki with lots of information and examples about configuration and using EMC."
    Also if you have a win 2000 or newer installation with a "real" parallel port you can try Mach and run programs up to 500 lines of Gcode with the trial version.
    I am replying on a 10.04 machine right now.
    Garry
    Aug 2010
    Kuwait
    thank you Mr.Garry for that information..
    I want Ask you some questions. What is "Hardy Heron"?? Is that a software or operating system?? And Where can I download it??
    Is that possible to install EMC on Ubuntu 10.04?? And how to install it??
    Sorry, But I don't have any Windows operating system right now..
    I need your help and thank you again..
    Apr 2003
    No you can't install Emc in 10.04 at this time without doing a lot on your own..
    Hardy Heron is Ubuntu 8.04... the last version there is a ready to run ENC version for. All Ubuntu versions are named..
    http://www.linuxcnc.org/content/view/21/4/
    is where you get this live CD version...
    If you really want to try the hard way then try this for 10.04
    http://wiki.linuxcnc.org/cgi-bin/emc...04PackageNotes
    Good Luck.
    Garry
