The table looks a little small and that's intentional. It's meant to
be used with more layers. Those layers can be offset front to back,
or even extended for various bolt on fixtures/jigs.
I made a few posts early on about using t-nuts and an easy way to
put them in place....
Also, the closer work can be brought to the bottom of the Z axis, the finer
the work can be. Leverage. Short bits are most always better when they can
be used.
Lots of possibilities with quick-change bolt on MDF fixtures.
John
Also...that's just a temp table til I get the other done.....
