Originally Posted by
atwooddon
Well, I finally got around to taking a picture of the new Z axis mount I threw together using brass tubing and some rails I had scrounged from old printers. The rails are only about 3/8" but over this small span, they are very rigid. The mount is on my old original DIY cnc machine I put together a few years ago. I am surprised at out rigid and smooth it operates compared to the original Z axis. The two pix below are the side/back view trying to show the way the brass tubes and rails go thru back of the router mount and a front view.
John showed a drawing of this approach a few posts ago. It was super easy to make using my V90 machine. The sliding on the rails is silky smooth and no matter how much pressure I put on one side of it trying to cause racking, it did not show any signs of that.
Don
