Attached is a spindle I am getting ready to build. I currently use a PC 892 to cut wood and some aluminum, but I would like to be able to achieve 100 to 4000 rpm, so I am building a spindle. Because I am using a screw-on chuck from porter-cable, all of my tooling is ready to use with it. I am going to redneck this a little bit, and just use the radial bearings that are used in my porter cable. Hey, they have lasted 3 years, with minimal runout @ 24000 rpm. The lower bearing on the PC router I have is a slide-fit onto the spidle, and it is "sprung" into position with a Beveled internal snap ring. There is a complementary bevel on the casing, and it will self adjust a small amount as the bearings wear. I intend to use that in my new spindle.
The servo I am going to use is the Torquemaster 3505 with C winding from Cleveland Motion Controls. The technical assistance guy told me that with my power supply (24V @ 31.5A) and the Gecko drive, I will have 5100 RPM max, with about 2.7 in-lbs of torque (at only 7 amps, about 3.9 @ 10 amps). Is that enough to make heavy cuts in aluminum, at a reasonable speed?
Without the encoder, it is $340 US, an additional $210 for the encoder. I will install my own to the spindle top.
Does anyone have any advice or recomendations before I embark on this 700 dollar project? My CNC is mainly 1/2" plate aluminum, and is more rigid than I expected. I think the mechanicals can handle it. I might have to get silly and try to cut some steel when it is finished...
Please help let my know any recomendations
