Ghostlx's 24x48 FLA build
Results 1 to 2 of 2
Thread: Ghostlx's 24x48 FLA build
    Registered ghostlx's Avatar
    Feb 2008
    Default Ghostlx's 24x48 FLA build
    While Nate is putting finishing touches on my fla 2x4 r&p I have beeen busy building my control box .
    picture 1 is what is left from a old 240 watt power supply..
    This let me have a fused link and a switch and a exaugst fan in one.
    Ran 3 wires from here to a 120vac plug in to have extra 115 power inside the case.
    and the on to the power supply leaving slack so i could slide the power in or out if needed to add more goodies later,
    but here are the first 3 pix
    more to come
    ghostlx
    Attached Thumbnails Attached Thumbnails Ghostlx's 24x48 FLA  build-gutted-pwsply1-jpg   Ghostlx's 24x48 FLA  build-gutted-pwsply2-jpg   Ghostlx's 24x48 FLA  build-parts-removed-jpg
    http://www.pure-teck.com/home.html
    Feb 2008
    Here is a few more.
    first a is a side view of the case , rear view , front view.and a close up of g 540.
    total cost case 0$ only cost is fan 8$ , electric box 4$, outlet 2$, 12vdc charger 1$,
    4 pin connector 2$, a gecko540 299$, 48vdc power supply 139.00$. and don't for get cables and motors. not a bad set up
    ghostlx
    Attached Thumbnails Attached Thumbnails Ghostlx's 24x48 FLA  build-side-view-case-jpg   Ghostlx's 24x48 FLA  build-rear-view-case-jpg   Ghostlx's 24x48 FLA  build-front-case-jpg   Ghostlx's 24x48 FLA  build-view-g540-jpg
