hmmm the link does not seem to work what did I do wrong
OK after quite a few weekends and some headaches she is getting close, finally got started on the web site so you can see some pis, here goes. see what you think
http://www.freewebs.com/raysplace/pics.htm
- trim router mounted to quill shaft... options and router selection?
- Woodworking CNC Router,stone CNC router machine, metal mould CNC router
- Quote Awarded Newest CNC router machine from SINICNC-SIN-C3636 Mini cnc router
- Need Help!- with a Precix Table Router with Perske router
- Using a router for the 1st time. Need advice of cut speeds, router bits etc.
Learn from the mistakes of others you can't afford to make them all yourself!
Ray (I assume Ray, since your url says raysplace),
This link worked for me:
Good work on the router.
Mark Linder
Good job there
Keep us up to date
Imagination is the beginning of creation. You imagine what you desire, you will what you imagine and at last you create what you will
