Hi
Pretty great so far ! As for the controller, had you look into the smoothstepper, it might be more easier to handle all the axis at same time and with less problem of connection to any pc too.
On the new stepper motor , the shorter one , as you said, what torque is it ? Have you loose torque by reducing or the gear let you have a more large headroom of available torque needed ?
thanks
