I wanted to weigh in here as I recently had trouble setting up an aftermarket XBOX 360 controller using the Mach3 XBOX 360 plugin. After constantly getting the errors that "No XBOX Controller Found", I figured out the issues with my specific setup. I wanted to put this out there to help prevent those doing this from dragging their heels for hours...
Here's a quick summary. I've also attached it in a PDF here.
- Follow the instructions on the Mach3 Plugin page
- I was using the Afterglow Ax-1 XBOX 360 Controller (wired version) and it was not working.
- Two things I had to do that were not readily evident. I had to go find the Vendor and Product ID's and enter them in the Controller config screen. When it still wasn't working, I found a posting that suggested that the Mach3 directory should NOT be Read Only. Mine was, and I removed Read Only on all files under c:/Mach3. It worked after this. Very happy after spending 2 hours on this.
