Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 01-13-2010, 05:32 PM
zonker is on a distinguished road
Touch probe or 3d scanner/ photo based
I want to carve/engrave on a 3d surface not a flat one and I am not sure a springloaded tool will take care of my needs. So I need the mesh of the parts. I do not need absolutely perfect detail I just need the shape to use in artcam or mastercam. Would you all recommend a touch probe or a 3d scanner? I think time wise I am better off with a 3d scanner. I also think I have a copy of 3dSom around here. Is there any reason a touch probe would be a better choice?
Visit Dagger and Rose 3D Vector Tattoos at http://daggrnrose.sqweebs.com
Old 08-24-2010, 11:57 AM
3DRevEng's Avatar
3DRevEng is on a distinguished road
I have a Roland LPX250 3d laser scanner for sale....
will sell for 2900$ and it comes with Pixform
http://www.stika.com/brochure_LPX250.pdf
Matthew
Old 09-07-2010, 02:24 PM
fergusda is on a distinguished road
3D scanning for sure. Even a lightning fast touch probe would take hours to reproduce surface of any significant size. I spent 2 years exploring and developing processes for reproducing 3D shapes as toolpaths.
There are a couple of free digitizing tools depending on your patience level:
www.david-laserscanner.com
http://mesh.brown.edu/byo3d/source.html
Or you can use one of the commercial scanner$. I've been using FlexScan3D with fantastic results for my own projects: http://www.3d3solutions.com/
I've got a little more write up on 3D scanning, CNC retrofits, and other fun projects at my website:
www.bluegalaxydesign.com
Keep in mind, scan data is an exact reproduction of the original surface, and depending on your process, may result in not-so-smooth G-Code and machining. To create true CAD surfaces takes a little more finessing.
-Dan
[IMG] code is Off
Newbie- Heidenhain TS-112 touch probe rooj65 Deckel, Maho, Aciera, Abene Mills 0 12-16-2009 05:16 PM
Touch Probe Babba Syil Products 11 10-11-2009 12:17 PM
TP100 Touch Probe help! Hambonin CNCzone Club House 0 04-16-2009 05:24 PM
Z axis touch probe Swede FlashCut CNC 7 08-29-2007 12:09 PM
homemade 3D touch probe? cnczane DIY-CNC Router Table Machines 26 06-26-2004 07:17 AM
