Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 03-29-2009, 12:46 AM
Khalid's Avatar
Khalid is on a distinguished road
Convert Photo in 3D Model..My setup.....No Lazer, No stitching ;)
Here is the small setup i made to generate 3D models from simple pictures..Following are the results of pictures i snapped at various angles.... it is than converted into 3D object..its marvelous.. No laser setup, no point cloud, no stitching of surfaces.. its give you complete 3D model within few minutes..
Once i made a wind mill for electricity generation.. I removed the blades from PM generator hub.. and pasted the grid patterns on it....
Rotated by hand and taking pictures (No camera stand required) ..almost 16 pictures in 360 degree angle...
ID:	78626   Click image for larger version
ID:	78627   Click image for larger version
ID:	78628   Click image for larger version
ID:	78630   Click image for larger version
ID:	78631   Click image for larger version
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 03-29-2009, 12:49 AM
Khalid's Avatar
here you can see some more work i did .. and check the smoothness of the model.. its almost accurate
ID:	78633   Click image for larger version
ID:	78634   Click image for larger version
ID:	78635   Click image for larger version
Old 03-29-2009, 12:54 AM
the4thseal is on a distinguished road
what software are you using?
Old 03-29-2009, 06:40 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Khalid,
Great scanning.
I would also like to know what program this is?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 03-29-2009, 07:16 AM
blackbeard52 is on a distinguished road
I assume you were manually turning the table?
Bob
Old 03-29-2009, 08:54 AM
Khalid's Avatar
Bob Yaa i turn the table manually
Okay here is the software web link.. Its easy you go there and read, download the functional Demo and do some testing..its very very simple...
http://www.3dsom.com/features/index.html
It make 3D model but it gives you no great details.. This model can then be imported in other softwares for sculpting like 3D StudioMax, Artcam, Zbrush, Aspire, MudBox etc.... its easy for me to put intricate details on these 3D Models...
I like the simplicity and really enjoy working..:-)
Old 03-29-2009, 09:30 AM
ger21's Avatar
But for $1500, most will probably prefer the $100 laser method.
Old 03-29-2009, 09:42 AM
Khalid's Avatar
Yes Gerry, you are right... .. I also after the David Laser Scanner.. and its almost completed
Old 03-29-2009, 11:40 AM
Switcher's Avatar
Moderator
Khalid,
Thanks for the info.
I thought you guys might like this?
This guy makes 3D models of himself & others, out of paper, not a lot of info on his website (software).
He also posted a PDF file of his head , dowload the file & you can see the tabs that he added (kinda like a puzzle)
[IMG] code is Off
Need A Quote- Lazer Cutting/Routing StupidDream88 Employment Opportunity 2 04-09-2009 11:31 PM
How much are torchmate plasma lazer? ariel 1 CNC Plasma and Waterjet Machines 2 03-22-2008 07:02 AM
Lazer Machine Help :( mtozer Laser Engraving & Cutting Machines 4 02-12-2008 09:53 PM
RFQ for lazer cutting some blanks Thomas_23 Employment Opportunity 1 11-03-2005 11:06 PM
How to convert 3D model to G-code? Peten General Metal Working Machines 16 10-13-2005 03:57 PM
