Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 08-26-2008, 08:09 PM
Bertho is on a distinguished road
Touch probe: Simple but accurate
I finally decided to build a touch probe with the goal of simple construction but preserving best stability and accuracy. See:
http://www.vinland.com/Touch-Probe.html
What software do you suggest that is free/low-cost to convert the point cloud to a mesh. I appreciate any help and suggestion. I have spent too many hours googling it already.
Bertho Boman
Old 09-01-2008, 01:36 AM
cncuser1 is on a distinguished road
Very nice job
Two comments:
- Dust getting inside will affect reading so try to seal it with something like thin rubber from a condom
- Make the probe tip removable and have an industry standard interface so you can cheaply use good quality, profesional tips in a variety of configurations
Old 09-01-2008, 05:18 AM
ger21's Avatar
Try MachCloud, it's free.
http://www.machsupport.com/downloads.php
Old 09-01-2008, 05:43 AM
Thanks CNCuser1,
The probe is actually designed to accept a 5mm threaded ball tip. That size has the largest number of available tips at http://www.itpstyli.com.
I do plan on sealing it but I have been too busy to follow up on that.
MachCloud:
I tried MachCloud initially since I am using Mach-3. It worked on a small sample but after hours of trying every possible combination I gave up. I posted the sample file at the Mach website but there is no support and no one else converted it. The AccuTrans is a great find for just $20.
Bertho
Old 09-01-2008, 06:54 AM
Karl_T's Avatar
Karl_T is on a distinguished road
I'm not much help, but I've installed a laser displacement sensor for my CNC mill. Got it working and then ran out of time. I'll get back to it in a couple months (winter project for me)
I bought rhino thinking it would work for this issue. This is, by far, the biggest issue for scanning. PLEASE, post if you find something you like.
Karl
[IMG] code is Off
Who want to make a touch probe? MrBean Digitizing and Laser Digitizing 114 09-30-2010 04:39 PM
k2CNC 3D Touch Probe Mike Stevenson K2CNC 0 02-14-2008 12:44 PM
Z axis touch probe Swede FlashCut CNC 7 08-29-2007 12:09 PM
Touch probe indexing carving1 WoodWorking 0 07-22-2007 02:03 PM
Touch Probe for a Noob. lilricky2 Digitizing and Laser Digitizing 26 02-02-2006 04:04 PM
