Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 09-23-2004, 10:15 AM
Freddy is on a distinguished road
Point Cloud
I got about 2500 points in a point cloud. Some follow a grid, but most are random. I had hoped to use a spline in Autocad then loft the splines, but I have too many random points that I need to get the most accurate surface. Any other solutions?
Software I have to work with:
Inventor 9
Mechanical Desktop 2005
Autocad 2005
Esprit 2003
Rhino 3
or what else would work best?
Old 09-23-2004, 02:50 PM
Graham S is on a distinguished road
I don't think there are any easy solutions, that is why you have to be careful about how you digitize.
Graham
Old 09-23-2004, 03:00 PM
turmite is on a distinguished road
Freddy I am not 100% sure but I think you can use Rhino, select the cloud, select the drape command and it will give you a surface....or something like it.
Again I have never done this but I have read somewhere that is what the drape command is for. Should be worth a try. I would also go to the Rhino newsgroup and pose the question about how to do it.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 09-23-2004, 09:07 PM
I don't think you can drape over a point cloud in Rhino, I couldn't anyway. But like Mike says it can't hurt to ask.
Graham
Old 09-23-2004, 11:18 PM
*Registered*
GWheeler is on a distinguished road
Datacad Dropmesh
Datacad (www.datacad.com) has a "Dropmesh" command in the 3d polygon menu. It drops a user-defined grid on a set of points or lines. A little like dropping a wet blanket on a bunch of objects. It attempts to model terrain and such but the perimeters of stiffness etcetera can be adjusted. I've used it for architectural models as Datacad is set up for architects and such.
I've got a web page at
http://g.wheeler.home.att.net/cnc.html
that explains some of the process, although it hasn't been worked on for about a year, you can probably figure it out.
Autoc*** can probably do the same.
Gary
[IMG] code is Off
Point cloud editing CNCgr General CAM Discussion 5 04-24-2005 12:06 PM
Software to manipulate point clouds? ckirchen General CAM Discussion 3 04-04-2005 09:07 PM
Where can I download Point cloud sample data ?? Calico Rhino 3D 0 03-19-2005 10:16 AM
point data in autocad trubleshtr General CAM Discussion 3 03-11-2005 06:32 AM
Point Cloud Conversions Fish General CAM Discussion 3 12-26-2004 09:13 PM
