Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 04-05-2008, 06:36 AM
irk3 is on a distinguished road
Router mounted david scanner
Hi Guys,
Have anybody tried mounting Web cam and a line laser on a router to capture 3D image using David scanner software. Pics are attached here of the router I have and plastic part I want to scan, would like to share comments and advice from the gurus.
ID:	56991   Click image for larger version
Name:	Plastic part.jpg‎
Old 04-05-2008, 06:47 AM
ger21's Avatar
There's a Mach3 plugin for doing that with Mach3.
Old 04-05-2008, 11:50 AM
pminmo's Avatar
pminmo is on a distinguished road
Gerry,
What is the name of the plugin?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 04-05-2008, 12:12 PM
ger21's Avatar
Video webcam point cloud scanner.
http://www.machsupport.com/artsoft/plugin.htm
Old 04-05-2008, 02:52 PM
blackbeard52 is on a distinguished road
Has anyone tried using the Mach plugin with the David scanner software for meshing?
Old 04-05-2008, 03:16 PM
ger21's Avatar
Art also wrote a little program to create a mesh from the Mach plugin.
http://www.machsupport.com/Downloads.../MachCloud.zip
Old 04-06-2008, 12:49 PM
pminmo's Avatar
Thanks Gerry.
Old 06-10-2008, 02:30 PM
DIY-Guy is on a distinguished road
DAVID software and the physical setup for 3D scanning.
Originally Posted by irk3 View Post
Hi Guys,
http://www.david-laserscanner.com/
Well, if you mount the webcam and the laser on the router to scan across an area, how will the DAVID software see any parallax at all? The DAVID software requires the camera to be mounted in one position, the object to also be stationary (in front of a special set of registration marks mounted in a 90 degree vertical orientation). The laser scan line is the only thing that moves. From what I've seen in the DAVID software documentation, the laser scan line generator needs to pivot up and down, from a fixed point.
Are we both thinking of the same required setup for DAVID software?
Sincerely,
DIY-Guy "Persuing low-tech, high-tech, CNC anyway I can get it to work!"
P.S. Try an inexpensive green laser as a source for your line generator, inexpensive webcams see that color much better than a keychain red laser pointer.
Last edited by DIY-Guy; 06-11-2008 at 02:41 AM. Reason: URL update required for clarity.
[IMG] code is Off
DAVID-laser scanner cadcoke3 3D Scanning 21 10-26-2011 07:08 AM
David Laser Scanner nancygal Digitizing and Laser Digitizing 4 08-14-2007 04:05 PM
