Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 03-01-2008, 09:49 AM
an-cadsolutions's Avatar
an-cadsolutions is on a distinguished road
digizing large parts with MicroScribe
I have MicroScribe G2X digizer arm and I use it with Rhinoceros.
Do someone experiense how to measure large parts with MicroScribe with moving digizer during the measure.
Regards
Antti
AN-Cadsolutions, Tampere, Finland
http://www.an-cadsolutions.fi
Old 03-01-2008, 04:24 PM
awerby is on a distinguished road
It's not that hard
Basically, you need to determine some reference points (3 is enough) that you can use to register the two positions to each other. Mark them on the part near the far edge you can reach (close to the area you'll be moving towards), and mark them in Rhino so you don't lose them. After you've moved the arm, pick those points again, then move the first set of curves (or points) you digitized previously so that the old 3 reference points now coincide exactly with the new 3 points. Make sure you look at more than one view when doing this, since you're working in 3 dimensions, not just two.
Then continue digitizing - the two scans should now be one.
Andrew Werby
www.computersculpture.com
Originally Posted by an-cadsolutions View Post
Regards
Antti
[IMG] code is Off
Handling large parts cdlenterprises General Metalwork Discussion 7 06-14-2009 11:13 PM
Locating Large Non-Square Parts on a Five Axis CNC Router Mexellent General Metalwork Discussion 0 02-04-2008 11:24 AM
Ordered a Microscribe joefox Digitizing and Laser Digitizing 1 11-01-2007 09:50 PM
Connecting to Microscribe 3dx robinsoncr Digitizing and Laser Digitizing 4 03-03-2007 01:26 PM
Large parts Molding techniques MBG Moldmaking 9 12-09-2005 01:44 PM
