| Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here! |
I build this dimensionally identical (internally) to Shaun Wainford's probe plans. I cut the top/housing/ring out of a 2" Delrin rod, and the hub out of HDPE using my home-built "7th Sojourn" dremel-based router. The pictures show a dart tip that I was using for testing but the digitized dime at the bottom of this post was acquired with a sharpened 2" long 6-32 screw tapped into the hub of the probe. As you can see from the images, the housing of the probe was modified to fit into the dremel mount. It's not as sexy as the probes you guys make out of aluminum but it works for me. Dime was digitized at .005" between points using Mach3 Wizard and then rendered in Rhino4. Last edited by aolshove; 10-31-2007 at 11:50 AM. |
| Neat! I really want to make one of these eventually. So, inside that thing you made the circuit board and 3-pins per shaun's design? R
__________________ Design & Development My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info |
Yep! Internally it's identical to Shaun's design. 2mm circuit board. The only difference is that I used imperial 2-56 screws instead of metric, 3/16" balls instead of 5mm, and 1/8" brass rod instead of 3mm "silver steel". |
I'm not exactly sure what you're asking. The board itself is laid out quite plainly in Shaun's PDF linked in the first post. The circuit itself is simply 3 NC switches connected in series. Open any one and you open the circuit. Each ball is in contact with the copper of the circuit board causing them to become part of the circuit. The brass rods embedded in the central hub contact two balls together thus making a closed switch. If any one rod is removed from its resting place between two balls, the circuit opens. |
| so... you etched thecircuit board in f.c. or similar? you built the housing on a lathe and used a grinder to make pins? i am probably not alone in saying that shaun's plans are complete, but difficult to interpret. all the same - i want one! the 3d scanner at camtronics is also tempting.. i wish there was a user forum of people who could let me know if it is worth the $~200 for a laser and the software...
| I found the plan's to be rather non-instructive as well but decided to forge on and just concentrate on making the various parts and see how they fit/worked together after cutting them. Half the fun was seeing how many of the parts I could cut using just the Newfangled Wizard in Mach3 and I cut all of them except the PCB which I had to layout in Autocad and toolpath the usual way. |
#10
| Why wait for a 3D scanner? Free 3D scanner: http://www.david-laserscanner.com/ Forum: http://www.david-laserscanner.com/forum/ Gallery (scan your own head) :http://www.david-laserscanner.com/?s...Gallery&page=2 . |
| Cheap home made Touch Probe. | mikegasman | Digitizing and Laser Digitizing | 35 | 11-15-2007 08:18 PM |
| Contour probe digitizing | Sanghera | Digitizing and Laser Digitizing | 1 | 02-04-2007 10:24 AM |
| Digitizing Probe Question | Trainhound | Digitizing and Laser Digitizing | 1 | 01-05-2006 06:25 PM |
| digitizing probe | sunmix | Mach Software (ArtSoft software) | 3 | 11-19-2005 09:52 AM |
| Digitizing probe question for newby | Kitch02 | Digitizing and Laser Digitizing | 6 | 03-30-2005 08:18 PM |
