Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 10-04-2007, 09:24 PM
Patternboy is on a distinguished road
Smile What to do with the file that come from a 3D laser scanner
Hi, I scan a small part on my CNC router with a 3D laser scanner from Optimet, I am getting files such as .stl, .raw or .dxf, can someone explain me what to do with the file so that I can use it to make a toolpath, I know it's mesh drawing, what software would I need to process that file to be able to machine the part.
Thank you
PatternBoy
Old 10-07-2007, 12:14 AM
debogus's Avatar
debogus is on a distinguished road
meshcam or cut 3d ,I believe are the cheapest
Old 10-07-2007, 09:11 PM
Thank you debogus for your reply, I have try Cut3D trial version and I was impress how easy it was to use.
I will be talking to my boss about it.
Thanks again.
PatternBoy
Old 10-08-2007, 12:52 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Most good CAD programs will let you import stls no problem -- but if you want to go right to cut and not do any adjusting, for about 50 bucks STLWork2 will make the Gcode for you. If you need to translate the files, a partner program is pretty good too -- ACUTRANS. They may still come bundled in a special. Not a dealer or associated - just real good value.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 01-31-2008, 09:09 PM
Hello all,
for debogus, what other softwares would you recommend beside Cut3D, I have this .stl file of 4.5GB (mesh type) comming from a scan that I did with a 3d laser scanner, I tried with Cut3D and it won't open, it did the one of 2GB but it took about 8min. to load with a pretty good computer P4, 3GB RAM. I tried with another powerfull computer (it can be use as a server from Dell 16GB RAM) to load that 4.5GB file and no succes. So what are other solutions, price is not an issue. Thank you.
PatternBoy
Old 02-01-2008, 06:43 PM
debogus's Avatar
price is not an issue ?
OH.
I have meshcam and it will open stl files from MOI(beta testing free version)
I'm just a hobbiest tinkerer so price is the biggest issue.
You said that it opened smaller files so its not a combatability problem (stl just the wrong flavor)
I dont know ,search up the food chain abit ,Rhino has a cam now ,dont it ?
I do know that big files are slow if not impossible on my computor ,but Im running only 2 gig and 2.4 ghz athlon with a not so neat video card( was cool about 3 generations ago)
Best of luck
Dave
Old 02-02-2008, 09:19 AM
Smile
Thank you debogus for your reply, I will search in the food chain like you said. I will tried Rhino.
PatternBoy
[IMG] code is Off
David Laser Scanner nancygal Digitizing and Laser Digitizing 4 08-14-2007 05:05 PM
Laser scanner software hllrsr Digitizing and Laser Digitizing 29 01-14-2007 04:29 PM
3d laser scanner uucww Product Announcements & Manufacturer News 1 10-04-2004 11:28 AM
