Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 04-04-2007, 07:42 PM
eloid is on a distinguished road
vac table with work Digitizer
Has any see or made a diy Digitizer used in conjunction
with a vac table clamp . This is what i want to do...
I have object ...place it on vac clamp, any which way on the clamp turn on the clamp . Now I want to use the Digitizer to locate the outer corners or
outline the object have mach 3 .. auto adjust the ref point to the object on the vac table?i
Then have it proceed cutting it out.
[IMG] code is Off
digitizer newstoneman Glass, Plastic and Stone 1 01-05-2007 07:06 PM
120x240cm(work area) Router Table - steel/aluminium Goose80 DIY-CNC Router Table Machines 9 12-13-2006 04:43 PM
Template digitizer plans bradboldrini Mechanical Calculations/Engineering Design 1 07-30-2006 02:41 PM
Okay all, I now need to work out belt reduction ratio's for my table. Apples CNC Plasma and Waterjet Machines 1 08-01-2005 10:28 AM
Cross slide work pc on rotary table replicapro General Metalwork Discussion 4 07-08-2004 06:30 AM
