Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 02-08-2007, 02:40 PM
santiago lisboa's Avatar
santiago lisboa is on a distinguished road
gasket help
Hi:
I am interested on cut some motor block gaskets (hi performance copper)
I will have to reproduce it from the original one. How can i do that with a digitaizer or similar.
Any advice will be welcome
el borincano
Old 02-10-2007, 01:01 AM
debogus's Avatar
debogus is on a distinguished road
I don't know the accuracy, but perhaps you can use a camera ?
Take picture ( higher the rez the better )
Ive read its better to use some distance to eliminate some of the lens distortion ( what I made didnt require this , just be square and center with the part.)
Use a picture editor to clip the pic to what you need
Note a few refernce dimensions
Load picture into vector program ( cad ,inkscape whatever)
scale until the pic matches your reference measurements
manualy trace over
send dxf to sheet cam( or what ever you use for g code)
I use this method on small stuff pretty well
I mean its easy and cheap enough if you make a paper one first to see if its what your after
Dave
Old 02-13-2007, 06:33 AM
Thanks,
Thanks for taking some time to reply. I will try it.
Old 02-13-2007, 03:27 PM
Normsthename is on a distinguished road
manualy trace over
I second this method
One thing you must do is take the overall dimensions of the original in both X & Y, and then scale the tracing in both X & Y directions.
If the bitmap is a good resolution it is surprising how accurate this method can be!
Andy
[IMG] code is Off
IH Gasket Repair help mattinaustin Industrial Hobbies (Support forum) 67 07-26-2007 09:40 PM
