Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 02-03-2007, 05:18 PM
Sanghera is on a distinguished road
Contour probe digitizing
I was wondering if there is a cheap software to convert the measurements made from linear plunger type encoders along a contour to a graph of some sort. I want to be able to have a precision shaft with a linear encoder on it attatched to a plunger encoder (which will be in contact with the surface I want to measure), so I have essentially an x axis and a z axis. I don't need the y axis. Basically it is two encoders, one for x axis and one that measures the z-depth. I want to be able to drag this encoder over objects to get a profile from the side. So I will end up with a 2d graph. The plunger encoder is:
http://www.usdigital.com/products/pe/
Do you know of any easier ways to do this?
Thanks.
Old 02-04-2007, 10:24 AM
svenakela is on a distinguished road
What you is looking for is a DRO (Digital Read Out) with recording functionality. I don't know if there's anyone cheap around, but it shouldn't a lot of work to do a DIY-version.
Regards,
Sven
[IMG] code is Off
Digitizing Probe Question Trainhound Digitizing and Laser Digitizing 1 01-05-2006 06:25 PM
digitizing probe sunmix Mach Software (ArtSoft software) 3 11-19-2005 09:52 AM
Bad Contour Error while Pocketing sundara BobCad-Cam 2 05-29-2005 07:10 AM
Digitizing probe question for newby Kitch02 Digitizing and Laser Digitizing 6 03-30-2005 08:18 PM
contour profile stevieboy Mastercam 8 10-15-2003 02:40 PM
