Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 01-12-2007, 10:05 AM
Rico55 is on a distinguished road
Need Laser Scanning Advice
I need to scan a wooden object that has a very shiny finish on it with our laser scanner. What can I spray or put on it to dull the finish, and remove later, without damaging the existing finish? I think the finish is a polyurethane, so it would be wipeable with water or a mild solvent.
Old 01-12-2007, 02:57 PM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
Use a dulling spray:
http://www.krylon.com/main/product_t...roduct_details
You can also use a food safe spray release agent. Don't overdo it with the spray...a little bit goes a long way.
-B
Old 01-12-2007, 03:08 PM
greybeard's Avatar
greybeard is on a distinguished road
Just come across a suggestion I'll pass on.
"Cheap hair spray, then dust with flour. ....It washes off"
Test first.
John
It's like doing jigsaw puzzles in the dark.
Why is there always more error than trial ?
Old 09-18-2007, 04:37 PM
bobscanco is on a distinguished road
you can use a material called: Spotcheck SKD-52 as well. I have had great success using this to reduce the reflectivity of the object i am scanning.
3DScanCo, INC Atlanta, GA
3D Laser Scanning Services
Reverse Engineering
Custom Scanning Solutions
3D Scanners
3D Scanning Software
Old 09-19-2007, 12:04 PM
cauldron is on a distinguished road
Although I haven't tried it personally, a suggestion I was given was a spray foot powder like Desenex. Basically, spray-on white powder. I plan on trying it on the next project I have lined up.
Old 09-20-2007, 09:33 AM
Harryman is on a distinguished road
You can try straight talc too.
[IMG] code is Off
