Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 01-08-2007, 03:54 PM
nancygal is on a distinguished road
David Laser Scanner
Check this out at:
http://www.cs.tu-bs.de/rob/david.html
Old 01-10-2007, 09:00 AM
rovingmind is on a distinguished road
David
You beat me to it.
Still, Awesome piece of software for anybody doing 3d work.
Old 04-30-2007, 11:53 AM
Timo is on a distinguished road
You can find the latest version of the 3D laser scanner software at
www.david-laserscanner.com
Old 05-17-2007, 02:56 PM
PolyPill is on a distinguished road
I had played with that a few months ago, it's pretty neat but I couldn't get it to work very well. I think my laser was bad, used a cheap laster leveler. I also had problems with getting the right lighting.
Although I think with a little bit of a $$ investment on the proper tools and work area it would work really well.
Old 08-14-2007, 05:05 PM
SteveC68 is on a distinguished road
Has anyone tried using a slide projector instead of a laser? It's mentioned in the the 3D for crazies thread, but I don't think anyone tried. It was suggested to use two pieces of electrical tape on a slide to make a slit and use the resulting white line as a "laser". I might try this if I can find a slide projector.
Also it looks like the camera used can have a big impact on the resolution of the digitized image.
Steve
[IMG] code is Off
