Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 12-07-2006, 10:58 PM
jabuffi is on a distinguished road
Smoothing Algorithims
I'd like to get a thread started about smoothing algorithims for point clouds.... Regardless of the source (ex. probe, laser scanner) most clouds don't generate perfect surfaces without "post-processing", so in the true spirit of DIY, anyone got pointers on how to to this? It go along way in helping those who are considering building their own probe or scanner and don't want to buy some of the high-dollared CAD/CAM software that supports this stuff... Plus it'll probably help those who do understand what's going on, which is always a plus...
Old 12-09-2006, 12:51 AM
Gold Member
CJL5585 is on a distinguished road
I'm in.
In what format are point clouds stored? I don't mean in X, Y, Z format guys. Is it like a comma delimited data file?
Jerry
Old 12-09-2006, 01:29 AM
It usually depends on what software you use to generate the points (i.e., using rhino to run a probe will I think get you a cloud straight into rhino that can be saved as a .dxf or .dwg), but anything homegrown would probably be easiest to store in a comma delimited .txt or tab delimited spreadsheet...
Old 12-09-2006, 07:19 AM
greybeard's Avatar
greybeard is on a distinguished road
Coming from a "know nothing" starting position, may I suggest that setting out a few examples of the sort of smoothing that is required is the first thing. Like defining what is the difference between a real "step" in the surface and what is a badly defined curved area, or just a piece of crud sitting on the surface of the object.
Do the "dust removal" programmes have anything in common with this ?
John
It's like doing jigsaw puzzles in the dark.
Why is there always more error than trial ?
[IMG] code is Off
