Page 10 of 10 FirstFirst ... 78910
Results 109 to 117 of 117
Thread: Who want to make a touch probe?
  1. #109
    Registered Drools's Avatar
    Feb 2009
    With the help of JayC and his CAM program (as I currently do not have one, a big thanks Jay) I made a touch probe from Delrin. Tough stuff to mill at 16K+ RPM. I used a 1/8 shank, 2 flute end mill. Also I used the dxf drawings from cognitivesolutions.
    here is a pic of the almost finished probe and what I started with.
    If anyone is interested in the gcode just let me know.
    Now I have to figure out how to load the plugin and start digitizing something. I have many somethings in mind
    Attached Thumbnails Attached Thumbnails Who want to make a touch probe?-dscf0064.jpg   Who want to make a touch probe?-dscf0067.jpg   Who want to make a touch probe?-dscf0068.jpg   Who want to make a touch probe?-dscf0069.jpg
  2. #110
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Thumbs up
    Drools,
    Nice work!
    Where are the DXF files posted?
    Thank You,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #111
    Registered MyCattMaxx's Avatar
    Dec 2009
    Quote Originally Posted by Drools View Post
    With as wide as the tip of that probe is what kind of resolution are you trying to get?
    It looks way to big to do lets just say the surface of a coin.
  4. #112
    Feb 2009
    I'm a complete noob to using a touch probe. If I need a new tip then I will make one but at this time I just don't know...
    I have seen tips using a ruby, why I don't know.
    I downloaded the dxf files from here
    http://www.cognitiveinnovations.com/news.php
    One thing I would like to add to the dxf files are index notches to the top and bottom so they line up easily. We had to make our own decision on the depth of the bottom as it is not given. We also had to be creative as the bit gets hot and melts the delrin, we add retracts to the code. retract to 1" then to 0 then to the new depth after each long cut. Often the bit will pickup a strand of delrin and act as a fan LOL.
  • #113
    Aug 2008
    I recently made a touch probe and a touch plate using most of the ideas from arie kabaalstra's design, pics are attached. This was the first real project I machined on my new CNC'ed X2, so I think it turned out great! What a learning experience.
    I finally started using it a few days ago after finding the Mach3 center/edge finding button codes that Hoss provided in his DVD's, they're awesome! But I'm having some SERIOUS electrical interference issues, it's falsely tripping every few seconds, and rarely ever making it all the way through a short center finding exercise. I figure it's gotta be a shielding issue, even though I'm using shielded wire, and no combination of shielding or aluminum foil "temp shielding" will result in a trip free setup. My e-stop is also tripping, so it hasn't been wired up. The shielded wiring for e-stop and probe doesn't have any other signal wires in that bundle, but they are zip tied to my stepper wiring (also shielded). The wired thing is that when I ground the probe shield wire, my steppers hiss at a different frequency. This doesn't happen for other shield grounds. So I think I'll have to run a new wiring bundle for e-stop/probe and see if that fixes it. Thoughts anyone? It's totally useless until I eliminate the interference.
    I don't have my tach hooked up yet however it does run in the same wiring bundle as the e-stop/limit/probe, so that might cause problems.
    If I had to make another probe, or maybe consider these tips for anyone thinking of make one yourself, there are a few things I'd change. First I didn't realize until a few days ago that the Wyoming guy is selling a similar one for $140, that's a STEAL of a deal. But with my design, the biggest thing I hated was soldering those stupid little wires to the pins and managing the wires in the housing. A circuit board would be SOOOO much easier and cleaner, and it would allow you to solder on a proper wiring plug which would make it a lot nicer to work with. I feel like these wires sticking out right off the solder joints are going to break on me one day. If it ever fails I will replace the nylon bottom part with some sort of circuit board. And heck, the fact that you're making it means you have a cnc mill, so whipping up a quick circuit board would take no time at all. I haven't done it yet but I can't wait to whip out a few little helpful boards. By the way those nylon things were machined out a cheap walmart cutting board. You can see that I wired in an LED, just like wyoming guy does on his, what a GREAT addition! You can even use it manually and know exactly when it trips, it's pretty cool. Wiring is shown in his PDF in the first post of the link above. Having it soldered to a circuit board would have been much cleaner. I kind of like how it's pointed down at the workpiece, shines a nice blue light on the edge that I'm staring at. Although having it pointed out towards your face would be just as practical.
    The ball beaing adjustment was a great idea incorporated into arie kabaalstra's design, mine seemed to be quite off center so that came in handy. However having the adjustment bolts on top was a bit of a pain, because I'd have to measure for concentricity, then remove it from the chuck, adjust, put it back, and measure again. Took about 30 minutes of dinking around to get it down to 1 thou. Somehow putting the adjustment on the bottom would be much easier. I sort of like Wyoming guy's method, although his use of RTV could be improved upon, I was thinking of a few small springs pushing the board down onto the adjustment screws (not to be confused with the spring holding the center triangle down).
    I went out and bought fancy 1/8" drill rod for the contactor pins and turned them to perfect domes and tapers on my cnc lathe, when any kind of steel, even aluminum might work just fine. It sees very very little force, you could machine the entire body out of delrin or nylon and not have any problems, just so long as you can adjust it to be truly centered. I made the 3 different tips out of 4140 steel (machines niiice) just because I didn't know what I would need, but I think the 1/8" ball probe tip will be fine for anything and everything, and if I'm doing a serious digitizing routine then maybe I'd use the pointed one.
    Don't be afraid to make it big. arie kabaalstra remarked how small his is at I think 1", which is cool and all, but mine is 1.5" dia and I found it to be pretty cramped inside there to route the wiring and that resistor for the LED. There's absolutely nothing wrong with having it really fat, 2" would be fine and give you way more room. I really like how wyoming guy threaded the different pieces so that they're really easy to assemble, and if I had an internal threading bar I would have done that too. (note to self, buy or machine an internal threading bar!)
    I don't have a picture of the assembled touch plate, but imagine the probe without the top and with the stubby plate tip on it facing upwards. The thought is to use it to set up a tool table for an automatic (or manual) tool changer. The crux of this design is that there's no adjustment to make sure that the touch surface is dead flat, and eyeballing it tells me that it's not. I'll use a dial test indicator to see how flat it is, if it's within a few thou then I won't care. Otherwise I might have to build a bit of adjustment in there somehow.
    Once I figure out this electrical interference wiring issue I can already see that this tool is going to be used all the time, it'll be SO handy for finding center and edges!
    Attached Thumbnails Attached Thumbnails Who want to make a touch probe?-dsc08916sm.jpg   Who want to make a touch probe?-dsc08919sm.jpg   Who want to make a touch probe?-dsc08922sm.jpg   Who want to make a touch probe?-dsc08924sm.jpg
    Who want to make a touch probe?-dsc08936sm.jpg   Who want to make a touch probe?-dsc08937sm.jpg   Who want to make a touch probe?-dsc08940sm.jpg   Who want to make a touch probe?-dsc08943sm.jpg
    Who want to make a touch probe?-dsc08947sm.jpg   Who want to make a touch probe?-dsc08958sm.jpg
  • #114
    Sep 2005
    Smile Good idea, and nice work!
    Been watching all these posts with great interest and I've abandon the PC board idea. Yours seems to be the way I am going to go, but with some changes. Instead of using steel rod and ball bearings, I did some checking using my digital ohm meter and some different materials. I seem to get less resistance using a machine screw with the threaded part making the contact, (for the pivot contact) in this case I am using round Phillips head stainless screws instead of the ball bearings. Part of the lower resistance is the fact that you are really passing very little current through the surfaces, and having the screw threads making the contact means several points of contact instead of just one.
    Just going to loop tinned hook up wire under the screw heads and solder on shielded stranded 2 conductor cable to my mini plug.
    Time will tell. Right now having a slight problem doing much after having surgery on my right index finger.
    BTW I am using this probe on a IM service CNC router.
  • #115
    Registered arie kabaalstra's Avatar
    Jan 2007
    Netherlands
    i'd stick to PCB design i if i were you.. i sold my design to DamenCNC in the Netherlands, after i altered the design a bit..
    the probe is now for sale at : http://www.damencnc.com/damencnc.php...=EN&idComp=230
    the copper pins have been replace with a PCB, with Gold-coated contacts soldered to it..
    of course i built one for myself ,and that's the one shown in the Youtube Film
    [nomedia="http://www.youtube.com/watch?v=5JnDloaC1YQ&feature=channel_page"]YouTube - USBCNC-Porsche 917K[/nomedia]
    @ Aspirator, Nice job!, though your's is slightly bigger than mine.. i should have becom a watch-maker perhaps..
  • #116
    Registered helliman 27's Avatar
    Oct 2011
    can you send me the dxf for the touch probe. i tried to find it on that site but no luck thank you.
  • #117
    Sep 2005
    Nice looking job on your probe
    Great looking job on your probe, but I have to agree with Arie, the pcb is easier to solder to.
    If you want to try my design check out my Digital Machinist article Volume 6 #4 Winter 2011.
    If it is too much work I do still sell these through CNC4PC.com or arnie@wyomingwireless.com , Peter Homann - from down under is selling these also for me.
    Thanks for the kind reviews of my probe!
    Arnie
  • Page 10 of 10 FirstFirst ... 78910
