Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
  #25
Old 06-13-2006, 06:46 AM
Gold Member
imserv is on a distinguished road
It really has nothing to do with an encoder. Any CNC machine that can follow a contour with a probe, 2D or 3D, can also simultaneously, drag a spindle along the same path. If it is done in real time, the probe stylus and the cutter have to be the same size to make a duplicate part. This assumes a single set of 2 axis slides for 2D, ie a single machine. A pantograph type of fixture could also be used for scaling, but NOT for cutter size compensation.
If the probing and machining are decoupled ( ie through a cad model and g-code) the duplicated part can be scaled, mirrored, modified, smoothed,etc.
There are usually limitations on the response time of a probe, that may make it possible to machine the part faster than it can be probed. Parallel port controllers have definite bandwidth issues with probing speed. That will probably be the limiting factor. For a serial port, dedicated controller like DeskCNC ( 125,000 sps), the physical switch opening and closing becomes the limiting variable. The DeskCNC probe can physically detect around 20,000 to 30,000 points per hour.
Fred Smith - IMService
  #26   Ban this user!
Old 07-08-2006, 07:31 PM
cncuser1 is on a distinguished road
Originally Posted by imserv
Just one of the many benefits of a serial port CNC controller. ;-)[/url]
Can someone explain this statement?
[IMG] code is Off
Mechanical Dektop 2004 dfx error fantasy2 Autodesk Software (Autocad, Inventor etc) 5 02-05-2005 07:39 AM
Digitizing Michael M AjaxCNC Control Products 9 01-18-2005 03:14 PM
Mechanical Detailer needed , Baltimore MD. area CNCadmin Employment Opportunity 0 06-09-2004 02:54 PM
Fadal 3d Digitizing WORKALONE Fadal 5 05-04-2004 06:39 PM
3d Digitizing WORKALONE Digitizing and Laser Digitizing 0 04-13-2004 02:23 PM
