Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 06-27-2006, 07:49 PM
ken12939 is on a distinguished road
Mach2 or 3 digitizing
How do I convert or post the txt file that the Mach2 or 3 outputs into a format I can load into Rhino3?
ken
Old 07-16-2006, 12:46 AM
turmite is on a distinguished road
Ken go to "file" then "open, import, or new" The file type menu will drop down in the middle of the screen. Scroll down till you find Point file! That will open it from where ever you have it stored. I put mine on the desktop since I don't plan to keep it after getting the model done. Once it is open you can save it as a 3dm file.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 07-16-2006, 01:27 PM
Mike- Thanks for the reply, one of these days I will give it a try.
thanks again ken
Old 11-13-2006, 05:54 PM
GuitarEng is on a distinguished road
mach III scanning
How fast does Mach III scan? Does it do a position and drop type of method, or is it able to traverse in a line across the surface?
I'm wondering how long it would take to scan say a 6" x 6" square at a .050" resolution?
Thanks in advance for any comments or suggestions..
[IMG] code is Off
