Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 06-19-2006, 05:47 PM
bfreedland is on a distinguished road
using a mitutoyo mtp1 signal probe
I've come across a mitutoyo mtp1 signal probe and I was trying to figure out if I can use it as a digitizing head. it is designed for a mitutoyo mx coordinate measuring machine. does anyone have knowledge of the wiring of the probe, it has a small 4 pin jack on the rear.
thanks
Barry
Old 08-29-2006, 12:09 PM
wiring for mitutoyo probe
so i've come up with an answer to my own question, but I thought I'd share as others may have or may be able to get a similar probe via ebay or other source.
I finally just took the probe apart and discovered that the insides are just a nice compact version of the do it yourself probe, with a set of led lights thrown in for decoration.
for wiring, with the probe tip facing down, and the connector facing you, the upper left and bottom right pins are an NC switch. the remaining two pins are for the led.
so far it seems to work well as a digitizer, but I still have to put the point clouds together.
Old 08-31-2007, 01:24 PM
aminear is on a distinguished road
mitutoyo probe
Good info, I just picked one up on Ebay today and was searching for info on it, and found your post doing a search.
Do you power the other two points for the led?
Thanks Arnie
Old 09-03-2007, 09:39 PM
no, I never bothered hooking up the led so I don't know which in the anode lead. But you do not need to hook up the led to use it.
-b
Old 09-07-2007, 12:28 PM
thanks for the info
Ok, thanks for the info.
Arnie
[IMG] code is Off
