Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 02-18-2006, 12:56 PM
Tazzer is on a distinguished road
DIY Probe wiring Q?
I thought I would try building the probe that is at http://www.indoor.flyer.co.uk/probe.htm I understand the contruction as it is pretty straight foward. However the wiring I am a little confused at, so I have a couple questions that I hope someone can answer.
Do you need a relay board that connects to the 3 axis controller board? Or does it connect straight to the 3 axis board? Or do you need a 4 axis board?
My CNC currently is using the Xylotex 3 Axis XS-3525/8S-3 controller board and Turbo CNC.
Any info will be great on how to get it wired up.
Old 02-19-2006, 08:07 AM
jerber's Avatar
Gold Member
jerber is on a distinguished road
Wiring is also pretty straight forward. It's just like a home/limit switch, just one wire to an input on your controller board or parallel port input pin and one wire to +5V.
Hope it helps.
Jeroen
____________________________________
Jeroen
Old 02-19-2006, 11:45 AM
Thanks Jeroen, however where do I pick up the +5v from, from the pc board or an external power supply????
Old 02-19-2006, 04:05 PM
jerber's Avatar
Gold Member
I looked at the Xylotek pdf of your board and on the right side should be some break-out screw terminals with +5V(Vcc) and parallel port I/O.
This is where you connect the wires, though I might advice to shield them and connect the shield wire to ground.
(Use an audio cable like on a headphone )
I don't know your board so others may be of more help.
Jeroen
Jeroen
Old 02-19-2006, 05:39 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
You can strip a usb cable and see! I pull +5 from there for other aps. Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 02-20-2006, 08:47 AM
jerber's Avatar
Gold Member
If you do that you will bypass every opto-isolation between the breakoutboard and the pc (if it has any).
Jeroen
[IMG] code is Off
