Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
  #13   Ban this user!
Old 02-16-2006, 08:45 AM
cncrich is on a distinguished road
in DOS or a Windows command prompt use fc.exe the usage is:
FC FILE1.EXT FILE2.EXT
that will put the differences on the screen
if there are no differences then it will say something like "no differences encountered"
if there are a bunch of differences you can output the data to a file
FC FILE1.EXT FILE2.EXT > DIFF.TXT
where diff.txt would be a text file containing the differences and file1.ext and file2.ext would be the files with the appropriate extension (usually .cnc)
  #14   Ban this user!
Old 02-16-2006, 10:39 AM
MIKE JEFFERS is on a distinguished road
paul
try giong to another dec place (.001 /.0001) it could be the software rounding up/down the values .with a surface it takes very little to achive this effect
set the resolution to 1 dec place and see the differance for an extreme scinario
mike.
  #15   Ban this user!
Old 02-16-2006, 10:48 AM
ViperTX is on a distinguished road
I didn't see any pattern on the physical dimples....maybe looking at the gcode and using Mike's approach with the data...you may see something.
[IMG] code is Off
