Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 10-20-2005, 02:49 PM
Cold Fusion is on a distinguished road
Possibly a different approach to manual digitizing?
Once again, need facilitates creativity. I've got lots of parts that are 2d with lots of holes and odd pockets. This would be a pain to do with point cloud system. Perhaps we could bring the operator into the picture a bit more. If the entire system could be moved by hand, it would definitely improve the quality of the data received because it would only be the necessary points determined by the user.
So here is what I thought of. A free sliding 2 axis frame similar to a tabletop cnc router. The Z axis could be a simple sliding axis with a leadscrew for raising and lowering a stylus. The key to the design is low friction and minimal skew. There are two options for encoders. Linear encoders could be installed along the rails, or rotary encoders could be attached with timing belts.
Now, what I'm confused about is inputting the data into Cad. With this type of system, isn't it possible to get arcs and lines instead of a point cloud system?
Have I completely lost my mind, or does this idea have potential?
Proud owner of a Series II Bridgeport.
Old 10-20-2005, 03:24 PM
HuFlungDung's Avatar
Moderator
Andrew,
If you do the joining of the points manually, you can probably do a much better job of reconstructing the object. Otherwise, you are likely to end up with a bunch of splines or a mesh to mess with, and most likely you would end up wanting to straighten up and simplify the model anyways.
I like the idea of the 3 axis linear scale idea, in some kind of gantry setup, guided by hand. However, in real life, I wonder if a person would find it too tedious to do?
I wonder what the users' working impressions are, who have used a Microscribe or Faroarm digitiser?
Old 10-20-2005, 03:42 PM
True. It might be a bit time consuming to operate, but for the hobby guys, that's less of an issue. In any case, the idea is to have something of similar capability but 1/10 the price of the Microscribe.
What is not clear to me is the software end. Is there a program that can take a direct signal from the encoders and reverse interpolate that into a managable format. I know mach2 can control a cloud point type probe, but that's going against the whole idea of this thing.
Old 10-20-2005, 04:31 PM
DieGuy's Avatar
DieGuy is on a distinguished road
Think spherical coordinates. an encoder on each pivot point and a known length between pivots and you are in business.
Old 10-20-2005, 10:01 PM
turmite is on a distinguished road
Andrew are you using mach software or Desk?? If so why not just program in the envelope and let the machine digitize the part for you. As Hu said far less boring and you can be doing something else while the work is being done????
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 10-20-2005, 10:38 PM
Mach2. Because I'm trying to avoid huge mesh files and wasted time scanning unneeded areas. The parts I need to trace are quite simple, except when you're triangulating every single hole by hand with calipers and parallels... With some sort of hand controlled gantry tracer, I could probably do the whole part in 5 minutes. Here is an example of what I would be doing.
Old 10-21-2005, 02:56 AM
Andrew all you need for that is 2 axis of recording with a accurate and quick way to move your probe up and down. Mach3 or Newfangle has wizards for digitizing but I am not sure it would do that.
Mike
Old 12-11-2005, 12:24 AM
HenryCNC is on a distinguished road
There are a lot of manual CMMs out there... if you could lock your Z axis and then manually push the X-Y axis around (with a touch probe, of course) you have basically the same thing. The software should just sit there are save XYZ points to a file.
Unfortunately, I can't answer the question of collecting coordinates.
You could bring that XYZ text file into any CAD software (I use Rhino) and make a 2D profile with very little trouble.
Old 02-12-2006, 12:05 PM
vmax549 is on a distinguished road
Mach DMM
Andrew I have posed the same question to the Mach group. I also do a lot of obsolete part replicating. If someone could write a wizard it could be a simple task. Jog over the hole insert probe, mach then does a probe cycle to determine center position and size of hole, move to next hole and repeat. You could also save points on other vertical surfaces. Then Mach would save out the points to be used in a cad/cam program. You can do the same thing manualy if you need to. You just have to do the work and center calculations but it is a lot better than having to draw it out manually. If I could program we would have such a critter. Mach is capable I am not. "MACH 3 DMM" (:~)=TERRY
Old 02-12-2006, 02:14 PM
JBV JBV is offline
*Registered*
JBV is on a distinguished road
Why not use a ordinary scanner? Just put the part on the scanner and a ruler, put some cloth over and scan at highest optical resolution...
Then you load the picture into a cad program and scale it correctly by using the ruler as reference. Then its easy to trace the lines and hole locations...
600 dpi = 0.001666" (0,042333 mm) resolution...
  #11   Ban this user!
Old 02-12-2006, 02:20 PM
I've tried the scanner approach, but it never works out cleanly. All the scans have a slight shadow on one side, which ruins the image when I convert to grey scale and do a raster/vector conversion.
  #12   Ban this user!
Old 02-12-2006, 03:31 PM
greybeard's Avatar
greybeard is on a distinguished road
If the scanner could lose the shadows..... ?
How about filling all the holes with a contrasting colour wax, then scan ?
John
It's like doing jigsaw puzzles in the dark.
Why is there always more error than trial ?
[IMG] code is Off
