Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 08-04-2011, 08:39 AM
CNC-Joe is on a distinguished road
Digitizing Newbie - has a lot of questions...
Hello Group,
I am new to digitizing, but not so new to CNC.
I am using Mach3 on my CNC Mills and CNC Router.
I recently built a Triangular touch probe from some files and information that were available out on the internet. It does work and provides a switch like input.
I know how to wire this up as an input to my milling machine, and how to configure an input in Mach3.
I downloaded a Plug-In from Mach3: ArtSoft USA - Plugins
A couple of basic questions:
1) How do I install this PlugIn in Mach3? So that Mach3 knows that its there?
2) How do I configure this as an input in Mach3 ? (I assume its a lot like my Z-zero plate, just hard wire it to an input on my Break-Out Board (a CNC4PC break out board), set the state in the Mach3: Config-> Ports & Pins-->Input Signals-->Probe.... )
3) After I get this puppy working - and collect a point cloud from digitizing an object.... what software is everybody using to convert the point cloud to an STL or ??? file?
4) After I have the solid model, I can use one of several softwares to create a tool path and machine the object (( Cut3D, Visual Mill, etc. )) - What software is everybody using? And how do you like it?
Any help is greatly appreciated.
Joe
JoeComunale (at) Comcast.Net
CNC Is Not Just My Passion.. It's My Addiction !!!!
Old 08-04-2011, 09:20 AM
Ok - here's what I've learned so far....
INSTALLATION:
- First download the digitizing file from Mach's website:
- it is called: Mach3 Digitizing Plug In Probing.m3p
- Double click on this - and get this will convert to:
Mach3 Digitizing Plug In Probing.dll
Which is a .dll file
-Copy this file to c:/mach3/PlugIns directory
Next - fire up Mach3
- use "Config" --> Config PlugIns --Enable it there
- Next "Config" --> Ports& Pins --> Input Signals --> Probe - and enable that to active low on whichever input port you have physically installed the hardware...
My Next Question: I can't find it under the PlugIns menu ?
Help?
Old 08-04-2011, 09:27 AM
Ok, Re-booted the computer, restarted Mach...and now there is a
"3D Probing" menu option!!
Now to get digitizing and collecting some point clouds...
Next Question: What software to use to mesh the point cloud, to get it into a solid model format ?
Thanks for any help.
(hope this amusing if nothing else)
Joe
Old 08-04-2011, 11:03 AM
ger21's Avatar
Joe, try MachCloud from the Machsupport Downloads page.
Old 08-04-2011, 11:36 AM
Thanks Ger! You're the man!
[IMG] code is Off
Several newbie questions. bill-the-cat Taig Mills & Lathes 12 08-09-2009 10:27 AM
Few newbie questions about CNC thedonutman Musical Instrument Design & Construction 4 02-12-2007 11:15 AM
OM newbie questions emceul Fanuc 2 10-10-2006 11:11 PM
Newbie and some questions..... skymaster DIY-CNC Router Table Machines 2 09-12-2004 05:11 PM
Newbie with Questions Wannabe General Metal Working Machines 5 03-20-2004 05:35 PM
