Results 1 to 11 of 11
Thread: digitize curved surface and engrave it
    Mar 2006
    Croatia
    has anyone come to a solution how to digitize uneven surface and then engrave something on it with automatic Z compensation when and how much required ?
    like this amazing datron machine does ...
    obviously software automatically calculate required Z compensation ...
    video of machine in action is on link
    Front panel samples, high speed machining*-*DATRON Dynamics
    Mar 2004
    Sweden
    Do you know if the panels are bent before or after the engraving? I know curved panels that are bent after the engraving.
    Otherwise, that would be a simple task if you have a CAM program.
    Mar 2006
    Croatia
    that's not the problem here ... as it's clearly visible from the attached video panel is bent before engraving, just to demonstrate software capability ... and that part, compensating for unevenness of surface is what bugs me ...
    Mar 2004
    Sweden
    Ah, didn't even see the video frame before...
    But now when I have seen it, it's not magic at all. They even show the pre-digitizing starting in the beginning of the clip. The part is simply digitized and the engraving is Z-level compensated. That could be done with a script for example a inside EMC2 before the milling starts (or outside). They've just included an automatic digitizing procedure. As I said, no magic (and doable even in my workshop).
    Mar 2006
    Croatia
    Interesting, never work with EMC2. I use mach3 ... do you know if it's possible to achieve that Z compensation in mach ?
    would it compensate if for instance you have straight line move let's say 100mm, and workpiece is wavy and has few bumps along that line ... would it compensate correctly or just starting and ending coordinates ? is it possible to actually machine a wavy curve along workpiece just with that script ?
    May 2010
    Quote Originally Posted by svenakela View Post
    Can you point me to that script/procedure? I have not been able to find it.
    -Bruce
    Mar 2004
    Sweden
    Quote Originally Posted by ecurb5 View Post
    -Bruce
    I didn't write that there is a script. I wrote that it could be done with a script.
    @turpija, I have very little knowledge about Mach3. I work with Heidenhain and EMC2 operated machines. But Mach3 is pretty configurable so it's probably possible.
    I do Z-level compensated profiles, the only difference between my procedure and the one discussed here is that I do it manually (Make profile, digitize, apply curve, post process, mill) and the Datron-guys do it automatically.
    Mar 2006
    Croatia
    Yes that's pretty straightforward ... manual way
    what still remain mystery is how to do it automatically ...
    let's get little visual, shall we
    gray surface is plate that has to be engraved or cutted
    red is toolpath created with coordinates from blue spots
    without a correction on some parts of board tool would not leave any marks, while on other it might be too deep
    what we seen on demonstration video is digitizing a grid of points and then automatically "bending" defined toolpath ... is it even possible to achieve with mach3 ?
    has anyone attempt that ?
    Attached Thumbnails Attached Thumbnails digitize curved surface and engrave it-asd.jpg
    Mar 2007
    Romeo, Michigan, USA
    This would be great to get working...
    I can see digitizing the stock of a hunting rifle or shot gun...
    then engraving a nice wildlife scene on it....
    Any one make any progress with this concept?
    [url]www.CNC-Joe.com[/url]
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Feb 2009
    Quote Originally Posted by CNC-Joe View Post
    Simple to do. Scan the part in with a laser scanner, import the scanned STL in to BobCAM, import artwork, merge with the scan using BobArt, create toolpath, start cutting.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Registered lwill's Avatar
    Aug 2005
    I just stumbled upon this
    This has been discussed in this thread:
    Cheap & simple height-probing
    Intended for PC boards but I made it work to engraving surfaces.
    It is for EMC, but you might get the gist of how it is done by looking at the code.
    1. 2d pocketing along a curved surface?
      By cgjeff in forum Visual Mill
      Last Post: 11-17-2010, 08:01 PM
    2. Cutter for curved surface?
      By flash319 in forum DIY CNC Router Table Machines
      Last Post: 09-02-2010, 10:36 PM
    3. Engrave on a curved surface
      By keebler303 in forum ArtCam Pro
      Last Post: 09-03-2009, 08:03 PM
    4. Need Help!- Curved Surface Toolpath
      By ehsanmax in forum Mastercam
      Last Post: 03-13-2008, 07:39 PM
    5. Rhino engrave text on curved surface
      By replicapro in forum Rhino 3D
      Last Post: 03-11-2008, 01:32 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
