Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
  #25   Ban this user!
Old 02-02-2006, 02:48 PM
Ed_R is on a distinguished road
OK so the point cloud issue is once again... cloudy.
In order to not hae to deal with the point cloud issue, I should get the box AND the probe. Right?
Here's teh trick- The PC that runs the machine is a 486-50 with DOS 6.2 on it. Will teh software even RUN on it? Or am I forced to point-clouding and saving, then transferring to the momma machine for massaging?
Old 02-02-2006, 02:58 PM
Gold Member
imserv is on a distinguished road
DeskCNC in a Box will run the machine from a Win98 or later computer with a serial or USB port.
A 486-50 with DOS limits you to a couple of DOS controller programs (TurboCNC and maybe Zeus) that will collect individual points, but won't offer any processing power for the resulting point cloud. I doubt that a 486-50 can hold the entire point set in memory, let alone display the resulting 3D surface file. It is not uncommon to create 20 meg data files of scanned surfaces. That's could easily be larger than the hard drive capacity on this machine. You will probably be limited to the amount of data you can put on a floppy diskette (1.4 meg) for the transfer, unless you are good at networking an old DOS box to a LAN, or maybe if you have a ZIP drive.
Fred Smith - IMService
http://www.cadcamcadcam.com/hobby
  #27   Ban this user!
Old 02-02-2006, 04:04 PM
I am plannign on starting with TurboCNC as my initial projects aren't complicated carves but rather just patern cutouts in 2-D space. The most complicated stuff is arcing.
For future runs I am eventually going to have to set up a nicer machine, but for now, I can transfer via USB key.
Might have to put off getting a probe for the moment but I am very interested in the technology and want to pursue it in future.
[IMG] code is Off
Z axis touch probe Swede FlashCut CNC 7 08-29-2007 12:09 PM
Touch Probe Amplifier Modifications itsme General Electronics Discussion 8 06-07-2005 08:57 AM
CNC noob needs a machine bootdc CNC Wood Router Project Log 7 05-18-2005 05:35 PM
Pop-up tool touch probe dmealer General Metal Working Machines 4 04-04-2005 06:47 AM
homemade 3D touch probe? cnczane DIY-CNC Router Table Machines 26 06-26-2004 07:17 AM
