Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 10-03-2010, 07:55 AM
LN-JET is on a distinguished road
DIY 3d digitizing using cable & angle encoders?
Hello,
From time to time there are questions about making Faro arm type equipment, which obviously is not easy to do.
I came across these products:
spaceagecontrol.com : Main > Space Sensor: 3D Sensing with Ease and Affordability
http://www.prodim.eu/proliner%C2-principle_674.html
They are restricted to line of sight measuring, but making a similar system should be feasible?
One would need one draw type encoder, and two rotary encoders.
The software must be able to export to a spreadsheet or convert spherical to cartesian coordinates that can be exported to cad. Can Mach3 or DRO SOFTWARE do this?
The mechanical bits must be some sort of low friction gimbal mount.
Please throw in your ideas!
Lars
Old 10-03-2010, 10:35 AM
ger21's Avatar
There's a thread with a lot of ideas on building a digitizing arm.
http://www.cnczone.com/forums/digiti...m_options.html
[IMG] code is Off
cheap absolute encoders? Oxymoron? Decent Incremental encoders? mattbesquare Benchtop Machines 15 09-08-2010 06:56 PM
AC power cable in the same cable carrier with motor cables bandtank General Electronics Discussion 12 06-01-2010 06:06 PM
Cable carrier competition: The way you use your cable carriers could earn you a cash igus Product Announcements & Manufacturer News 0 01-22-2010 12:06 PM
Sheilded cat5e cable for encoders? Splint General Electronics Discussion 18 01-28-2008 09:08 PM
Info on encoders and digitizing Zathras Digitizing and Laser Digitizing 0 10-15-2005 09:37 AM
