Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 06-04-2005, 03:54 AM
itsme's Avatar
itsme is on a distinguished road
Building a probe
Hi there,
I've searched through the net and this site to try and find info on making a digitising probe. I know very little about digitising (my CNC mill isn't even running yet...), but it must be possible to make a simple probe that works reliably with reasonable accuracy.
Does anyone know what exactly is 'inside' a probe and what it would take to build one?
Warren
Have a nice day...
Old 06-04-2005, 07:44 AM
Karl_T's Avatar
Karl_T is on a distinguished road
http://www.indoor.flyer.co.uk/probe.htm
Karl
Old 06-04-2005, 08:50 AM
*Registered User*
ChrisJ is on a distinguished road
Check out industrialhobbies.com
They show instructions on how to convert a edge finder that has an led light to a touch probe. I think that this type requires that you make contact with a metal surface since it is looking to sink to ground. So, if this is true, it would only be good for digitizing metal/conductive surfaces. If you wanted to do nonconductive surfaces, you would need to build a switch in the probe which when depressed (ever so slightly), would close the circuit.
Chris
Old 06-04-2005, 08:57 AM
hughesbros is on a distinguished road
I can't remember where these drawings came from. The probe works a lot better than the one MaxNC supply.
I increased the diameter on the one I built, I figured the further apart the balls were the more sensitive it would be.
The tip about tinning the PCB board improved sensitivity a lot.
Regards Mark.
Hughes Tooling.
Old 06-04-2005, 09:28 AM
itsme's Avatar
Thanks for the replies everyone.
I think all this information should get me started on something. My mill isn't even finished yet and I'm already trying to find extra attachments to put onto it. I hope I have time to make something with the mill oneday, other than parts for the mill...
Thanks again
Warren
Have a nice day...
Old 06-04-2005, 09:57 AM
*Registered User*
Karl and Mark, nice probe designs.
Thanks also.
Chris
Old 06-04-2005, 09:58 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Chris
This is true... but in my limited electroplating experience, one may be able to coat the surface of non-conductive items with a conductive "paint" (spray or brush) allowing use of this type of probe. I haven't done any of this with a probe, but have had success in electroplating non-conductive items (years ago).
..of course this all depends if the item to be probed is up for the "paint job".
Old 06-04-2005, 10:09 AM
*Registered User*
Could you suggest some products that we would have access to for your conductive spray paint suggestion?
Thank you for the reply!
Chris
Old 06-04-2005, 10:21 AM
Bloy2004's Avatar
Fumbling Machinist
Chris
I can't really advise on those conductive coatings....its been SOooo long ago, some of the electroplating companys are non existant now.... I DO remember though that I had made a mixture (to save a few bucks) as an alternative to the comercial coatings by using a medium to hold powdered copper. I don't recall if I fully tested it.
...geesh.. I'm not THAT old...just a bad memory or "too many irons in the fire" at that time.
Old 06-04-2005, 11:53 AM
itsme's Avatar
Hughesbros, I assume that you are using TurboCNC, since you posted in the other thread I started in the TurboCNC section. Could you please tell me if your probe uses a 'point' on the end or a ball? The reason I ask, is that TurboCNC doesn't have cutter radius compensation and I'd imagine that if a ball were used, then the points written to the text file would be inaccurate. Am I correct in thinking this?
Warren
Have a nice day...
  #11   Ban this user!
Old 06-04-2005, 05:25 PM
itsme's Avatar
Hello again,
I've had a good look at all the information that was given earlier and I think I've pretty much sorted out the actual probe design in my head. My attention is now drawn to the 'amplifier'.
Is an amplifier really necessary, or can I simply run 5V through the probe directly to the parallel port? I would obviously like to make it as simple as possible, but if an amplifier is needed, then I'll have to make one.
Warren
Have a nice day...
  #12   Ban this user!
Old 06-05-2005, 06:49 AM
I'm using a MaxNC CL control on a machine I built. Like TurboCNC there is no compensation for the probe diameter, but I can offset the surface in Rhino. I used a 1mm diameter probe to scan the face in the image attached, the surface on the left has been offset 0.5mm inwards to compensate for the ball.
Mark
Hughes Tooling.
ID:	8029   Click image for larger version
[IMG] code is Off
Building a stepper motor. tastefulasever Stepper Motors and Drives 13 12-11-2009 11:50 AM
Pop-up tool touch probe dmealer General Metal Working Machines 4 04-04-2005 07:47 AM
Digitizing probe question for newby Kitch02 Digitizing and Laser Digitizing 6 03-30-2005 08:18 PM
Tool setting probe JFettig Mach Software (ArtSoft software) 18 03-12-2005 08:33 AM
DeskCNC TP-100 Probe released imserv Product Announcements & Manufacturer News 7 03-11-2005 09:10 AM
